Josh,
You are comparing two different length scales. Full bevel convexity (as Clay has shown) requires “large” multi-micron abrasives.
Micro-convexity involves just the last few microns of the edge and only requires sub-micron abrasives. These sub-micron abrasive strops do not remove enough metal to convex the entire bevel.
The suggestion is that micro-convexity is the key to maximizing keenness.
I would suggest that you try following the C10k with a 0.25 micron diamond on balsa at the same angle and see what you think.
Todd.
You are correct Todd in that I was comparing two different things… I was aware of that when I posted it up but I was wondering if it would be beneficial to reduce the angle slightly even on balsa to minimize the micro convexity and just barely caress the edge for the sharpest edge possible. Basically, just what Clay advocates on the larger scale taking it to the micro scale.
I will definitely try what you say. thank you!
