Steel will cut jack
Recent Forums Main Forum Steel will cut jack
  • #47707
    Reaper
    • Topics: 5
    First time sharpening D2 on the wicked edge system. Markered the blade found the sweet spot matched the angle on both sides and went through the stones finished with ceramic and I am very happy with the edge. AABFA0EB-E0BA-4968-828F-9D0F4D61E6D4
    #47710
    That’s all that really matters is that your happy with the results.  What angle did it match at?  D2 steel has a wide range of hardness, from 55 to 62, on the Rockwell C scale, depending on how it was hardened and tempered.  So the steel could be from what would be considered soft to pretty hard on the other end of the scale.
    I’ll be curious to see how it stands the test of time and use.
    Dan
    #47711
    Reaper
    • Topics: 5
    The angle was pretty close to 20 degrees per side 20.35 on one side and 20.45 on the other chose to go with 20 degrees. I EDC this knife in rotation for work everyday and have found I like the 20 degree angle for cutting of shrink wrap and cordage that I cut everyday. The steel will is not expensive but being knew to the WE system I wanted to try sharpening D2 on an inexpensive blade. As my confidence gets better I will move up to the lapping and polishing as you much more experienced gentlemen do. I would also like to thank all the members that are willing to give me the benefit of their experience. I am glad I found this site. You are willing to share your knowledge without hesitation no matter how simple the question.
    #47724
    Travis Johnston
    • Topics: 8
    I have found I can get my D2 cutjack super sharp
    #47727
    That’s a great looking bevel Travis! You did a good job clamping the blade in the sweet spot as evidenced by the even bevel width across the length of the blade.
    #47728
    Reaper
    • Topics: 5
    Travis what degree angle did you use on your cut jack ? That is one great looking bevel
    #47800
    Travis Johnston
    • Topics: 8
    I think I did that one at 17 dps
    #48352
    Travis Johnston
    • Topics: 8
    Just did a Mini Cutjack, FDE color. Super sharp
    #48385
    Reaper
    • Topics: 5
    Great looking edge I really like sharpening the cut jack
    #55467
    Adam
    Would you by chance have the setting you used to clamp the knife I seem to be really struggling to find the sweet spot
    #55473
    Adam, welcome to the Wicked Edge forum.
    I have not personally sharpened this knife.  From looking at the photos of that knife posted earlier in this thread, it appears you’re pretty limited to how you can clamp that blade.  I’d attempt to clamp it on the narrowing tapered curving parallel flat plane surfaces on both sides of the knife just below the spine bevel.  I’d try to position the knife in the vise jaws so it’s clamped as far forward, towards the tip, on the knife as possible.  If there’s not enough height on the flat spot to find a secure purchase for the jaws then I’d slide the knife so the jaws are just as far back as is required, to find the flat spot height needed to get it clamed securely.   As you clamp the knife further back on the blade closer to the ricasso you’ll gain more height in the curved flat spot.  This may allow you some clamping adjustability to rotate the knife so it’s positioned just slightly more “tip up” as clamped.  This may help with finding the “Sweet Spot”.
    Realize that every knife we clamp in the W.E. for the first sharpening will undergo some small amount of blade edge profiling, seen generally at the extreme ends of the blade, tip and heel, as the blade coordinates with the fixed angle sharpening method used with the W.E.  Each subsequent sharpening will not require further edge reprofiling as long as the first clamping position is used again.
    I wanted to add, it’s not necessary for the knife to be resting down on the depth key pins whenever positioning and clamping a knife.  The only requirement is that the knife be clamped stationary and securely.   If it requires the knife be positioned so it’s just held by the very jaws tips to find a good clamping position then “so be it”.  Still use the alignment guide positioned with the depth key to record the knife’s clamping position and for future touchups.
