side centering thick blades
  • #7895
    Peter Lee
    hello, I’m new to this board. I enjoy reading all the great information and expertise on the WE here.
    Got upgrade II kit with the riser & new ball joints & wanted to ask advice.
    is there a reliable way other than trial & error ensure perfect centering of the knife? My bevels from one side of the blade to the other are always a tiny fraction of an angle different. I do use the 2-pronged guide to sit the blade heel on – but I’m not talking about gross centering here. I’m talking about exact, precise, perfect centering.
    also, what’s the best lube for the steel ball to aluminum contacts – ?mineral oil ?silicone oil ?Rem oil ?militec?
    also, my top screw tightener for the aluminum pyramid clamp still pokes through to the other side & damages the diamond stones. Should I grind it down or does Clay offer an upgrade to the pyramid clamp & screw kit to fix this too?
    Thanks all.
    #7896
    Mikedoh
    Have you read this thread
    http://www.wickededgeusa.com/index.php?option=com_kunena&func=view&catid=9&id=4781&Itemid=63
    As far as the screw getting hit, you may need to ge a shorter screw, or position the knife above the upper holes and tighten upper screw just
    enough for contact, and tighten mostly with bottom screw. You may have to fiddle a bit, and be aware that you could possibly bend the vice jaws if you torque the bottom screw too much.
    Haven’t lubed anything on my WE.
    HTH
    #7899
    Xbander
    Check out – WE Wiki under Resources on the web page – In the “New User Info” these is a number of videos and discussion on bevels, might help.
    I do use the Rem oil every so often to lube and clean out the arm joint. The rem oil is light, so no concern it might gum up the works.
    #7901
    Peter Lee
    Thanks Mike & James for the assistance – I’ll check out both of those links.
    #7906
    Chris
    • Topics: 7
    Thanks all.
    This has been discussed a few times before, I remember Clay saying he would include a shorter screw.
    Will this still happen?
    #7909
    Chris
    • Topics: 7
    The ball-bearing joint Clay uses has a nylon bearing “race”.
    Nylon is meant to be self lubricating.
    Water is a lubricant for nylon.
    I would not use anything that could react with nylon.
