Shear sharpening?!?
Recent Forums Main Forum Product Announcements Shear sharpening?!?
  • #45726
    Shawn
    I’m wondering if anyone has figured out some sort of jig for sharpening Japanese style hair stylist shears? The shears do not have a bevel along the cutting edge, but instead have a radius that makes up the cutting edge. Also most have an 800mm radius curve from heal to tip. I believe the 800mm radius would be kept in tact just by keeping the stone moving over the length of the blade, but the small radius that makes up the edge would need either the stone to swing over the back of the blade or the blade to swing down so the stone can reach the back of the blade. I’m sorry for my terrible description, I have three children running around here and I’m constantly being interrupted. Lol
    #45730
    Hi Shawn:  Welcome aboard!!
    Can you show us a photo of a typical shears you have in mind?
    #45741
    Shawn
    These are the best I could come up with from my phone. I hope they help explain, as I seem to be having trouble coming up with the words. Thank you for your interest.
    #45745
    Shawn
    A couple more.
    #45748
    In your photos, it looks pretty much like the barber’s shears I usually do.  If I understand you correctly, you’re looking for a convex edge, as opposed to a flat bevel edge.  This can be done on the WEPS by following the procedure outlined by Clay in one of his videos here.
    I did a convex edge on an old kitchen knife recently, just to test a new method I had been thinking about try on my Gen 3 Pro.  I started the bevel as usual, working toward the establishment of an apex.  Having done that, I switched to my 800 grit and moved the angle to the next lower detent.  After about  5 or 10 light strokes, I dropped to the next lower detent, did 10 more, then dropped another detent step, did 10 more and repeated this until I was happy with the overall look.  The number of strokes you take is dependent on the blade thickness.  If you have a very thin blade, more than one or two strokes could wipe out the prior flat.  Then I went back to the highest angle and restarted the sequence with my 1000-grit stones.  I repeated it with my 1500-grit stones and my 6-micron film.  The trick seemed to be a matter of not taking too many stroke at any particular stage, as you could create just another flat bevel.
    Note that I described a procedure for putting a convex edge on a knife.  When using the WE scissor attachment, you would start at a low angle and increase the angle with each step.
    I only tried this once and it worked after a fashion.  Being less than impressed with the results, I re-profiled to a standard bevel, but it looked to me to be another viable method of creating the convex edge.  I think I’ll try it again on my Victorinox chef’s knife, which had something similar to a convex edge on it from the factory.
    #45752
    Shawn
    Thank you for getting back to me and explaining how you achieved the convex edge. I will try to locate that video and give it a watch.
    #45831
    sksharp
    • Topics: 9
    Sometimes sharpening the same as the manufacturer is not the best for the knife, or in this case scissors. I have not personally seen an convex edge that will perform the way a straight edge will. I do however understand your desire to retain the integrity the way the scissors were designed. Good luck
    #45833
    Shawn
    Thank you sksharp
    #45867
    Beckbuilt
    Shawn, I wanted to chime in here because I am a shear sharpener.  I bought a scissor adapter for another sharpener and the WE is really no different.  I am optimistic on a lot of things sharpening and this idea is one I feel can only be adopted if you want mediocre results.  I can sharpen a bevel edge scissor on my knife sharpener. It’s easy and any bevel would be.  They turn out great.  I bought one prior to starting business.  The thing to consider here is the angles are flat not convexed.  People talk about a convex edge in knives as having one or multiple angles outside of the finished angle, but in a convex scissor remember there is no straight bevel, but one curve.  They are talking about adding micro-bevels and get closer to final apex. Microbevels on a convex shear are bad.  The apex on a scissor is where those two edges meet in space along the line of the two blades coming together.  That’s not such an issue for knives.  If your apex is left or right of center not a big deal it can still be wicked sharp.  The blade can be bent, and knife will still cut.  Not in a straight line but it will cut.  Consider the scissor has to be two blades in a line.   I own a machine that costs thousands to do what you are asking.  A convexing jig requires a rotational component to turn the scissor blade around a radial point to form that convex outside.  My clamp jig holds each blade and once I have the angle set on the minimum rotational angle or what is the blade angle for the scissor I then rotate my wrist to follow that convex edge over to that stop I just set.  IF I hold it there for any fraction too long bevels begin to form not good.   For reference that last pic is what we are speaking of.  Any stylist would consider that shear destroyed.  It might be fixed by rolling back the beginning of the new convex edge to the leading-edge side of the bevel and rework it.  I know a guy who fixed one like you have.  Most won’t bother because the amount of metal removal required makes this shears blades so short the ability of the shear to cut might be compromised by lack of steel remaining for integrity.  Essentially, I start off doing test scratches until I get the angle high enough to scratch right at the very edge of the blade.  Too steep of an angle starting out to begin with and you destroy that beautiful beginning thin edge at worst ruining it (like yours) and never cutting with it and at best killed years of use from a good scissor. I get the idea of multiple small straight line passes at different angles to sharpen the blade, but the WE is first and foremost a knife sharpener. Used to create bevels of varying angles that meet at an apex.  I can have a scissor torn apart sharpened, lubed and back together in under 15 minutes.  If you did the technique as described above on a convex scissor blade you would have to set the angle, sharpen, change jig angle finite amount resharpen, over and over.  I’m thinking hours of work.  All the while hoping you never create a bevel on the leading front edge. The exact thing a WE is designed to do very easily!!!The other option rotate the jig in one hand and try and apply motion with the stone in the other which also defeats the main advantage of the WE (Freeing your hands up so run stones)  The main advantage to a shear sharpening machine is clamping the blade and having the jig to hold the radius constraints for you.  I am sharpening free hand with rotational limits on a flat abrasive disk.  WE is a jig fixture designed to maintain the same bevel or angle.  It’s what makes it work so well for knives, but don’t try that with a convex edge scissor.  Convex scissors are so finite in their convex angle I literally have sharpened a blade that 1 degree more or less from ideal can be the difference between that scissor cutting like they should, or a stylist coming back to me and say redo it because it’s not cutting at all.  Use the correct tool for the correct job.  Shawn there are jigs out there, but they typically are the focal point of a machine made for doing exactly what you want.  If you are looking for a project to fix that blade mount it like TC stated.  Work from the front cutting edge and roll back till you reprofile that edge to look like the others.  Obviously make sure the other blade is the same.   I can’t imagine doing that myself on my WE, but if I had a few hours where I wanted to try I might attempt on one of my shears I use for demonstration.
    • This reply was modified 7 years, 4 months ago by Beckbuilt. Reason: verbage not right
    #45873
    Shawn
    I was looking at the Hira-to fixture assembly to deal with the convexing of the edge and getting a machinist friend to make a jig that would hold it at a constant 90* angle. Do you think a set up like that would work? The reason I was asking if anyone had come up with a jig of some sort was cause the Hira-to fixture is still $1300, I dont mind paying that but if someone had figured out a more economical way to go about it I wanted to know. Thank you for taking the time to respond to my inquiry Beckbuilt, I agree with all you are saying but in your opinion would the addition of the Hira-to fixture solve all the problems with the WE sharpening shears?
