I’m not sure I understand, are you talking about that the tip area is wider? (Nothing entirely wrong with that, it’s mostly looks… it’ll actually cut better).
You can create a “more obtuse” angle at the tip, just follow the instructions on this page…
Positioning the knife front to back
You’ll want to set the knife similar to the third knife down… where it’s removing metal more toward the edge. You’ll end up with sort of a “double bevel” for a while, but again, that’s mostly aesthetics. Something like this…
I wouldn’t grind until the old bevel is gone… that’s a waste of metal, and could actually cause some issues.
Hope that helps… apologies if I didn’t understand what you’re asking.
