Reduced Stropping angles
Recent Forums Main Forum Stropping Reduced Stropping angles
Viewing 1 post (of 1 total)
  • #46708
    I’ve been sorting out my photo files recently and came across some old photos that illustrate one or our axioms – that of reducing your angle by one or two degrees when switching to a soft platen material.  Compliant platen material can roll over an edge and soften the crispness of what would have been a very sharp knife.
    These micro photos were taken in April of 2014 – a little more than four years ago.
    The knife shown in the first two pictures is a standard Buck 110.  I had sharpened it to 1000-grit (photo #1), then switched to 3 micron diamond film.  The annotation should explain the situation.
    buck 110 b4 glass film Comp
    buck 110 3mic film Comp
    The second pair of photos are of a Buck Prince, which also had been sharpened to 1000-grit before switching to 3.5 micron paste on leather strops.  No angle change was made and the effect on the edge is quite apparent.
    buck prince b4 stropping Comp
    buck prince 3 5 strop Comp
