“Precision” Sharpener
Recent Forums Main Forum “Precision” Sharpener
  • #59014
    Kyle
    For those that bought the system before the newer clamping system, have you ran into this issue?
    The lower pusher screw looks as if it was incorrectly drilled/tapped and heli-coil inserted. I cannot get the heli-coil back in and continue using my sharpener, which is highly inconvenient seeing how I have several knives needing sharpened before a trade show this weekend
    #59015
    000Robert
    • Topics: 7
    For those that bought the system before the newer clamping system, have you ran into this issue? The lower pusher screw looks as if it was incorrectly drilled/tapped and heli-coil inserted. I cannot get the heli-coil back in and continue using my sharpener, which is highly inconvenient seeing how I have several knives needing sharpened before a trade show this weekend
    It would help if you were more specific. Which system do you have? It would also help if you could provide some pictures.
    #59016
    I experienced something like that many years ago, also with an older version standard vise. The heli-coil pulled when I removed the screw.
    If you submit a ticket with WE support, I’m sure they’ll replace your older vise with the current version.
