Paramilitary 2 Sharpening
Recent Forums Main Forum Techniques and Sharpening Strategies Paramilitary 2 Sharpening
  • #857
    Zach
    Looking for a little advice here.
    I’m sharpening my Para 2 on the wicked edge w/ 34 degree inclusive angle. Seem to be having some difficulty at the heel. There is a very small area at the heel that the stones don’t hit. I clamp at position 2 and line it up to B. any advice would be appreciated.
    #858
    don griffith
    • Topics: 4
    Well, short of putting choil to grinder or hand sharpening the area on a bench stone, what is it about that area that needs sharpening? It seems quite small. I know I’ll face the same issue with my Spydies when my WEPS gets here, but aside from aesthetics what would someone cut with that small length?
    #859
    Jende Industries
    • Topics: 14
    Try turning the stone so the corner of it gets in there. There may not be enough room, though….
    #860
    Zach
    Doesn’t affect function but bugs me cause the rest of the knife has a beautiful mirror polish.
    #861
    Zach
    Not enough room choil is in the way.
    #862
    I know exactly what you’re talking about, the rim of the tray that holds the stone hits the choil which blocks the stone from the last 1/8″ of blade. You could trim the plastic away, or pick up a couple Choseras, they’re thick enough that the tray doesn’t interfere with the choil. I’ll scratch my brain for other solutions too and get back to you if anything presents itself.
    #1324
    Michael
    I’ve just bought a few Para 2’s and will be facing this too. A picture of how much to trim would be helpful.
    #1331
    Rafael Jorge
    What if you take the knife apart and mount just the blade on the WEPS?
    #1332
    Zach
    Wouldn’t change anything as the stone mount would still hit the choil.
    #1361
    CAWalter
    Same here and sanded part of the tray off to the stone edge on the 400 & 600 just to keep this area even with the rest. Could do it to all the stones, but 600 in that first 1/8″ seems to be fine.
    CAW
    #7852
    Mark
    Sorry to dig up an old thread here but I have the exact same issue sharpening my PM2 and was wondering if:
    A. Will the new arm upgrade help this issue? I have one on order. I suspect it won’t but thought I would ask.
    B. Other than sanding the plastic on the diamond hones or using the Choseras, are there any other options that would work with the diamond/ceramic stone?
    BTW, love my WE and with a little experience and patience I can get edges better than I ever have in years of other methods 🙂
    #7853
    Hey Mark, welcome to the forum!
    It’s not the exact same knife, but I think if you mount the knife so that the edge is more parallel to the clamp, like I showed a few posts down in this thread…
    http://wickededgeusa.com/index.php?option=com_kunena&func=view&catid=9&id=7126&Itemid=63
    It should also create better clearance in this area.
    Let me know if that works or not.
    #7854
    Mark
    Thanks! I’m new to this forum but have been using my WE for a little over a year now. Great resource you have here in the forum!
    I tried different mounting positions in combination with both depth locations and no luck. The plastic of the handle hits the pointy bit on the choil by the ricasso as shown in the first photo in this thread, making it not possible to use the stone on that last part of the blade.
