There’s a few of YT videos showing some technique doing this…. hair whittling with Wicked Edge. ModifiedZ has one that’s almost an hour that’s pretty detailed, smokeeater908 has a brief one that’s worth watching too. (Both should be near the top of the search).
I watched ModifiedZ video and followed it exactly. Took about four hours to do my knife. It came out seriously sharp! But not hair whittling? I was however able to tree top a couple of arm hairs but even that was pretty sad?
I did notice at the end of ModifiedZ video he writes in he could not whittle hair till he used .5 paste.
Are you guys using the paste or am I just missing the boat?[/quote]
I guess I’m into old threads today…
I found that holding the paddles for a consistent angle was key. Since there’s play between the paddles and the guide rods, you may not be hitting the bevel exactly the same with each pass (I measured a .4 to .5 degree variation). I used ModifiedZ recommendation: grasp the paddles so your index finger rests at the top and pushes toward the clamp, while rotating your wrist slightly to pull the bottom away from the clamp. This way you hit the bevel at the same angle every time. The first time I tried this, I produced a solid hair whittling edge.
-Pie
