Mod a Generation 3 clamp
Recent › Forums › Main Forum › Sharpener and Accessory Maintenance › MODS › Mod a Generation 3 clamp
- This topic has 6 replies, 3 voices, and was last updated 07/10/2018 at 6:30 pm by
GaryH.
07/09/2018 at 11:40 am #46856
I have a Generation 3 clamp (Original with out the split jaws) that I have never used. I am considering modifying it in order for it to work like the latest edition of the Generation 3 clamp. has anyone cut a relief split in the jaws in the older clamp? I have a lot of FFG Spyderco knives and thought it may work better at clamping them.
thanks
07/09/2018 at 3:55 pm #46861Gary I’d be interested to see what results you get. If you do it please share your experience. I don’t know if there’s any real advantage to having the split jaws with-out the tension adjustment feature incorporated with the newer version vice. I don’t see the split jaws really flexing unless I really clamp with a lot of pressure. I don’t believe the older vice develops that amount of clamping tension.
If you are going to try to cut a split down the jaws I’d be sure to drill a hole first for the bottom of the slot to avoid splitting/breaking the jaw’s aluminum when using them.
(MarcH's Rack-Its)07/09/2018 at 5:47 pm #46862Thanks
I will let you know if I mod it. Mght just order the Gen 3 system and sell the one I have.
07/09/2018 at 6:15 pm #46863Gary if you’ve never used it, possible you can discuss with Wicked Edge if they’ll let you ship that one in to them for the modification. That is the addition of the jaw tension adjuster if it can even be added to the older style vice. The split jaws can be purchased as an add-on accessory.
(MarcH's Rack-Its)-
This reply was modified 7 years, 1 month ago by
07/10/2018 at 2:06 am #46867I agree with Marc… I think that WE would sell you a new jaw assembly.
I also agree that cutting a single kerf in the center to a small drilled hole on each side of the jaws should give you the additional flex that the new jaws provide. And as Marc says, the hole would serve to limit the possibility of any crack propagating from there. We just need someone to chime in with the distance from the top of the jaw to the bottom of the slot as well as the width of the slot, which would also answer the question of the preferred hole diameter. The slot doesn’t have to be a specific width, as the flex will happen between the hole and the sides of the jaws, hence a single saw kerf.
07/10/2018 at 8:12 am #46870Gary in reference to my suggestion above to send in your old vice to Wicked Edge for a parts upgrade including the tension adjusting box, after further consideration I remembered there are other differences in the older, original version, Gen 3 vices. Theses have an open sided vice housing, different cam springs and cam followers. These differences may make the old version Gen 3 Vice incompatible with the new version Gen 3 features like the vice tension adjusting box.
I, like you, have an old first version Gen 3 Vice that predates the tension adjustment and split jaws. On this jaw pair the left side jaw has four depth key holes, two side by side holes on top, for the shallow depth clamping position and a second pair of side by side depth key holes lower down for the deeper knife clamping position.
The right side of this jaw pair has vertical rounded slots opposite and in alignment with the right side two depth hole pairs.
To cut a third slot in the center may be an option on the right but probably pretty difficult to do on the left side in between the existing slots.
The jaws on the newest version Gen 3 Vice only have the upper and lower depth key holes and the right and left jaws are the same and also are interchangeable, side to side.
As you can see the relief slot in the new split jaws is orientated at the center and at an even depth with the center of the bottom depth key holes.It may be worth the try to see if cutting the slot helps. You have nothing to loose if you’re prepared to buy the vice upgrade and change it out. I can say having owned and used both the first version and the latest version Gen 3 vices that the newest vice with the tension adjustment feature and split jaws does work very well for my needs and uses.
(MarcH's Rack-Its)Attachments:
07/10/2018 at 6:30 pm #46884Thanks for the pics. I am thinking I should just try the WE 320. If it works out I will just sell my WE120 and include the version one clamp with it.
