Mini grip in 154cm
  • #1491
    David
    • Topics: 14
    So I just took my benchmade mini griptilian in 154cm to the WEPS. Since I only have the full set of diamonds and some strops I finished at 1k and stropped down to .5u. It has a pretty nice mirror and push cuts well I even shaved part of my face with it last night but it won’t pass the hanging hair test. Do you guys think I need to strop more, or wait till I have the ceramics then strop down to .5u, or to Pass the hanging hair test do I need to go down to .25u or lower?
    #1500
    Hey David,
    What angle did you choose?
    –Clay
    #1504
    David
    • Topics: 14
    Hi Clay,
    I took it down to 16 degrees per side. Do I need to go lower?
    #1505
    16 degrees should work for the hanging hair. Did you try the hanging hair immediately after stropping the blade?
    #1509
    David
    • Topics: 14
    No, I tried it after doing some other tests. It was kind of an afterthought.
    #1510
    The other tests may have been enough to blunt the edge so it wouldn’t do the hanging hair.
    #1511
    David
    • Topics: 14
    Ok, so coming off the 1k stones then 5u, 3.5u, 1u, and .5u strops should create a HHT passable edge? I sent the swing arms in to get the new modification done on them. So once I get them back I’ll hit it with the strops real quick and post the results.
    Thanks Clay!
    #1515
    Larry
    • Topics: 5
    Clay
    What is the mod to the swing arms, is it something we could do ourselves without needing to send it in.
    Lucky
    #1518
    Clay
    Lucky
    Hey Lucky,
    The mod is fairly simple if you have the tools for it; the first step is to push out the pin connecting the black Hinge to the blue Collar – if you have a drill press, it’s easy to do with a 1/8″ bit or piece of rod. The next step is to tap one side of the Hinge for a #8-32 Button Head Cap Screw 3/8″. The hole in the Guide Rod and the hole in the non-threaded side of the Hinge need to be bored out to allow a close fit for the screw. I’m also using 0.125×0.23×0.01 washers from Drillspot though the mod works well enough without them. I reassemble using the screw in place of the pin and tighten it up. I like to get it fairly tight, then put a drop of oil in and work the rod a few times until it moves smoothly. You can us some purple loctite to keep the screw from loosening up. I hope that helps.
    –Clay
