sorry to hear the trouble your having David. I bought the Super Fine ceramics as a go between from the 1000 diamonds to the Micro Fine ceramics, and I use them in that progression and have not lapped mine ( other than against themselves ) but I’ve had no issues with them…….except that on the Micro Fines once, the stones came loose from the paddles and fell off…………..which I then used medium thick CA glue to re-adhere them which worked out great.
Here are a few pics of one I recently finished ( a re-sharpen or touch up if you will ) starting at the 600 grit diamonds going through both sets of the ceramics, then finally the balsa and leather strops. It came out with a REALLY nice mirrored edge, and very sharp.
Thanks Ken! Super glue seemed to work. I only hope I put enough on, and that its sitting flat(I just put glue on top of old glue and clamped it). We’ll see!
Contact adhesive is my favourite to use for two reasons it is user friendly and when the stone needs replacing putting the paddle in boiling water will soften the glue enough to remove the stone remains then the remains of the glue can be removed with an aluminium scouring pad .
Epoxy or super glue really is permanent so there is no way to reuse the paddle in the future . 3M do contact adhesive in an aerosol similar to spray mount but it is for fabrics or formica etc I prefer an old fashioned tin since spraying small areas does not work so well and there is a lot of wastage.
