Lapping the Micro-Fine Ceramics
Recent Forums Main Forum Sharpener and Accessory Maintenance Ceramic Stones Lapping the Micro-Fine Ceramics
Viewing 15 posts - 16 through 30 (of 34 total)
  • #7554
    Phil Pasteur
    • Topics: 10
    My coarse Micro-Fine stones were more coarse than I wanted at the moment, so I took them all the way up to the 1000# diamonds, progressing from the 100# stones up the line. I also have a 3um diamond bench stone that I used to finish and the coarse Micro-Fines were like a whole different set of stones. “
    Is what Clay said that he did… in the first post in this thread…
    I used the DMT coarse, then DMT fine plates. It seems to me that this put the stone in the corrct sequence with the Other ceramics. It looks that way in the photos I took as well.
    I think that if you just use the DMT extra fine plate, you will have to work the stones for quite awhile to make a significant change. You can always try and see how they work on steel.
    #7622
    Gary Crumb
    I have all of those (course and fine are a double sided) so I will start with the course and run the gamut checking them after the fine and if needed go on to the extra fine.
    #7729
    [Quote]have all of those (course and fine are a double sided) so I will start with the course and run the gamut checking them after the fine and if needed go on to the extra fine.[/quote]
    Dunno what a gamut check is, but sounds interesting…
    #7731
    Zach Thompson
    • Topics: 10
    Gamut: an entire range or series
    It’s not a gamut check. He means he will go through all of the stones, then check the results.
    #7744
    Gary Crumb
    Thank you, sir! That is precisely what I meant.
    #7813
    Chris
    • Topics: 7
    My crazy logic here, but I wonder if having two sets of micro-fines that are manipulated to replace/remove the 1200/1600 role in a progression is possible?
    The first stone being “as it comes” on the coarse side and made coarser on the fine side. (not sure)
    The second being “lapped finer” on the coarse side and standard on the fine. (possible)
    Can we make the fine ceramic coarser with lapping?
    #7820
    Good question. I’ll do some testing.
    #8806
    vlad8
    Do you lap only the coarse side or both?
    #8808
    Ken Buzbee
    • Topics: 14
    People have done one (usually the coarse side) both, and neither.
    I would try them stock for a bit. See your results. Then decide what, if anything you want to do
    Ken
    #8814
    Phil Pasteur
    • Topics: 10
    I only did the coarse side of the microfine set. Keep in mind these things are extremely hard. I marked them (bad idea) with a sharpie. After 45 minutes on a DMT coarse plate. I barely touched the marks. I think they, at least the ones that I got, are pretty darn flat out of the box. Mostly what you are trying to do is re-texture then a bit. Even that takes a bit of effort. I finished on the DMT fine stone. This seems to have slottted the coarse stone into the progression just as it is rated. I never had any reason to lap or retxture the fine side… so I haven’t touched them.
    I thought that lapping/texturing the coarse stones worked by removing or altering the top layer left in the manufacturing process (something like the Kiln layer that Clay mentioned in relation to the other ceramics??). Possibly to get to the “true grit” below that.
    If the stones are homogenous, it is hard to imagine that you can make them more coarse than they are.
    #8818
    I held off lapping mine when I first got them… I thought they were fine. When I did lap the MicroFine-Coarse (I never did the fine), I found it did have some type of noticeable layer on it, that when removed, the stone performed better. (I still think it falls above the 1200/1600 stone though). I did rub the Fine side together, but didn’t see much difference… they work well though.
    #8821
    Phil Pasteur
    • Topics: 10
    Hey Curtis,
    What do you mean by “falls above” the 1200/1600? As in, maybe, you think it has a finer grit than the 1600 (which is what I think that you meant)?
    Or perhaps the opposite, I couldn’t exactly tell from your statement. Probably just me on a Monday morning
    Just curious, as I find it a close call. On some knives it seems like the coarse may be adding scratches after the 1600. In any case, I usually use the microfine course right after the 1600 though. Is that what you do as well?
    I need to take some photos…
    #8825
    Ken Buzbee
    • Topics: 14
    It seems more coarse than the 1200, to me. If I use all four I go coarse micro->1200->1600->fine micro, but I rarely ever do that. If I’m going to use the ceramics, I just use the micro alone, skipping the 1200/1600 altogether.
    Ken
    #8830
    Yea, what Ken said… MicroFine Coarse –> 1200 –> 1600 –> MicroFine Fine. Even after lapping it still seems this way, although I’ll admit I haven’t spent a lot of time looking at it… just seem to get better results with this progression.
    #9639
    Matthieu Methot
    I used my micros one time and I thought they needed lapping right away. When I started lapping I did it the way clay discribed with my 100 grit first but I hadent cleaned the diamond stone and I am glad I didn’t because it showed the high and low spots on the ceramics.It took over an hour to flatten and I did most of the work with the 100 grit stones just to get the high spots out. Now my 100 grit stones are less agresive than my 200 grit stones. I would buy a cheap coars diamond stone to flatten them then work through the rest of your we stones. I would like to see if someone could mic there micro ceramics :blush: before they start so I know how much I sanded off.
