How to obtain a mirror edge?
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › How to obtain a mirror edge?
- This topic has 23 replies, 8 voices, and was last updated 03/28/2012 at 1:49 am by
wickededge.
01/13/2012 at 10:21 am #1353
I am about to buy the Wicked Edge system, probably from the German reseller. Living in Europe, that avoids me having to pay high import taxes and transport costs.
I’ll buy at least the base package, with the 100/200 stones and the 400/600 stones, as well as a pre-drilled base, which the German guy seems to make himself. I’ll likely also order the 800/1000 stones.
From there on, I’m so not sure. If I base myself on the grit table on this site, I could either get the strops with 5/3.5 micron stropping paste for polishing after sharpening at 1000 grid. And then even finer stropping stuff, if I wanted to.
Or instead I could get the 1200/1600 stones. If I wanted to do stropping afterwards, I’d have to start with 1 micron stropping spray (since 1600 grit translates to 2.85 microns). And again, I could go even lower if I wanted to.
My goal would be really to obtain a mirror edge. Which of the two approaches would you recommend? Start stropping after the 1000 grid stones or also use the 1200/1600 stones? Is stropping even necessary after using the 1600 stones?
In this respect I am a bit confused by the video in which Clay sharpens a knife with a somewhat convex edge (the CRK Sebenza – which I own and want to sharpen to perfection) and starts stropping already at 10 microns (presumably after finally sharpening at 800 or 1000 grid) and then moves down to “only†5 microns. Using this he is able to get a mirror finish. But according to some other messages you need stropping at smaller micron sizes for a mirror edge.
So basically my questions boil down to: if I want to obtain a mirror edge, what would I do after having sharpened my knife on a 1000 grid diamond stone:
* Start stropping at 5 microns, then 3.5 microns and possibly even less microns, e.g. 1 micron?
* Continue sharpening at 1200 and 1600 grid, and then stop? (Not strop :).
* Continue sharpening at 1200 and 1600 grid, and then strop at 1 micron or even lower?
* Or an entirely different strategy, for example what Craig showed in his Sebenza video?And a related question: how far do you need to go with sharpening/polishing in terms of micron size in order to get a mirror edge?
I know there are also Shosera stones out, by let’s leave them out of this equation, for the time being, not to make this already complex discussion overcomplicated.
Thanks a lot for your answers!
P.S. I posted a similar message in a reply in another threat. That one was quite old, so maybe that was why nobody replied. Nevertheless, sorry for posting two quite similar messages. It is just that I want to order a WE this weekend and I still need some advice.
01/13/2012 at 11:53 am #1354I get a nice mirror edge using the 5 micron strop. The 1000 grit stones give the edge a beautiful ‘glow’ but not quite mirror. I have not used the 1200/1600 stones.
01/13/2012 at 3:50 pm #1355I use the 1200/1600 stones and get a mirror finish everytime after stropping to 3.5 microns. Sweet!
01/13/2012 at 4:37 pm #1356There’s mirror finishes, and then there are mirror finishes! :silly:
In general, you’ll get a “hazy” mirror at the 2K level (8 microns), a basic/light mirror at 3K (6 microns) and a full mirror at the 4K-6K range (4 microns to 3 microns) and a “bright” mirror from 8K and finer (2 microns and smaller).
This is loose reference, since the abrasive, technique and way the abrasive breaks down will all affect the resulting level of mirror.
If you are going for absolute perfection in your mirror (with little or no errant scratches), I personally recommend the diamond compounds and/or Choseras over the ceramics. Even the diamonds and Choseras make different mirrors, though!
01/13/2012 at 8:56 pm #1357Thanks all! I’m looking forward more and more!
I’ll also get the 1200/1600 stones. I only don’t quite understand the following:
According to grits comparison chart on this site, 1600 grit translates to 2.85 microns. If you then strop with 3.5 micron stuff, aren’t you actually dulling the blade, rather than making it sharper? Wouldn’t it make more sense to strop with 1 micron stuff?
01/15/2012 at 2:52 pm #1362I don’t know, but it sure buffs up the edge.
01/16/2012 at 5:13 am #1365Anyone got any ideas on this? What is the best particle size to start stropping with after the 1600 grit stones if I use the diamond paste/spray?
01/17/2012 at 11:39 am #1375Call me dense, but I’m just looking at the Grit Comparison Chart here on the WEPS site. From the pictures, the stropped edges look to have a better polish than the water stones. So why get the ceramics and water stones at all? Why not just come off the 1000 diamonds and go to the 5 and 3.5 micron strops? Then go to the 1 and .5 micron strops if you want an even better polish.
Or am I missing something? :huh:
01/17/2012 at 1:55 pm #1378Hi Doug!
It is difficult to answer the question with a yes or no. Some metals respond better to diamonds than they do to the stones and even between the Choseras and the Shaptons you will get different results. The stropping definitely adds to the polish and also tends to convex your edge the more you do it.
So here goes…once you get beyond the 1000 grit stones you enter the area where extreme sharpeners dream of polishing molecules so their edges shine like the sun and slice through things like a hot knife through butter. I believe it isn’t necessary to go beyond the strops as you ask, but after I sent my 4 knives to Clay for the sharpening test using the Shaptons and Chosera stones, I have to admit the edges he developed with those stones, paddles and strops altogether were of a very high order mirror finish and were as sharp as anything I have ever seen in 6 decades of looking bar scalpels made of obsidian used in surgery. Hmm! Now that I mention that, I will have one of those used on me soon and twice in the next 6 months. Then I will personally find out how sharp is sharp.
I don’t know if I even came lose to answering your difficult question, but I hope this helped.Best regards
Leo01/17/2012 at 2:19 pm #1379Thanks for the answer Leo! So do you think that the harder and high-tech steels like ZDP-189 are better with diamonds, and the more conventional steels are better with water-stones? Or is it more complicated than that?
Hope the surgery goes well for you my friend! Insist that they use something sharp. :cheer: Have some Lagavulin on hand for your recovery! Best wishes, my friend!
Doug
01/17/2012 at 2:56 pm #1380Thanks for the answer Leo! So do you think that the harder and high-tech steels like ZDP-189 are better with diamonds, and the more conventional steels are better with water-stones? Or is it more complicated than that?
Doug
The first part of your question would be better answered by someone like Tom from Jende Industries…he sells the Chosera stones and is a really knowledgeable guy about all things to do with sharpening…see his video on shaving with a knife he sharpened. It is complicated and each steel is different so there are a variety of approaches. I love 1095 and A2 tool steels…they are respond well to the diamond paddles
and the ceramics followed by the strops with diamond pastes. Usually that is as far as I go unless I am experimenting and Darlene is out of the house, then I bring out the wet stones Choseras, soak them so they develop a slurry as you go and keep the spritzed with water. The results are extraordinarily
good and I use these for my finest knives like my PXL from Fallkniven with 3G laminated powder steel or my STS-5 combat/survival knife with CPM154 SS. Send a PM to Tom at Jende Industries and he will be happy to add to you knowledge in this area.Thanks for the good wishes. I have kidney stones in both kidneys and have had 6 surgeries over 38 years…the dang things keep on growing back in. You can be sure I will have some Lagavulin and/or Laphroig sitting next to me when I return home after each surgery. That won’t be for awhile though so meanwhile I think I will have a tipple of Laga now before bed when I dream of bent vises…the Lagavulin will help me have a dreamless sleep I hope! ROTFLMAO!
Best to you chum
Leo01/18/2012 at 11:45 am #1385Thanks for the answer Leo! So do you think that the harder and high-tech steels like ZDP-189 are better with diamonds, and the more conventional steels are better with water-stones? Or is it more complicated than that?
DougThanks for the intro, Leo! B)
Basically, you can make it as easy or as complicated as you like! :woohoo:
The grit comparison is by microns, which is the most mathematically correct way to present them without too much confusion. The size of the particle equals the size of the scratch.
Well, yes, and no. You need to take into account the friability (rate of break down) of the abrasive and binder, the action of the paste/swarf/slurry, if any, and the biggest variable – technique.
Technique first – heavier pressure is good for stock removal since it pushes the abrasives deeper into the steel, but light pressure is best for obtaining the best finishes that won’t cut through the ever thinning edge of the edge. What is heavy and what is light has some defining parameters, but is ultimately different for everyone.
Action of the paste/swarf/slurry – Diamond plates are subjected more to wear-down meaning that diamonds start off with sharp jagged and pointy edges that cut aggressively. For simplicity, imagine the diamond is in the shape of a pyramid, the tip of the pyramid is sharp and pointy, but as the diamond wears, the pointed area becomes wider, with a larger surface area as time passes that doesn’t cut as deeply. This is advantageous on finer grits. The dust from sharpening will also clog the surface on the plates, making less of the abrasive stick out, therefore slowing down the action as well while making it perform at a finer grit. The WEPS ceramic stones follow this same premise, only without diamonds.
Diamond paste is a different beast – it has the freedom to roll around and scrub the surface more than to scratch at depth, like the fixed diamonds on the plates. In other words, the pastes are “less” aggressive, and are better suited for polishing surfaces rather than stock removal. That’s a basic answer to why the higher grit diamonds are in paste form. On leather, the softness allows for a cushion that will round the edge of the edge over, but on something a little more solid, like balsa, the pastes are more aggressive.
Choseras work on several levels – They start off using the actual grit to scratch, but as this happens, abrasive and binding agent gets released and mixes with the abraded steel particles and breaks down, forming a paste. This paste, when worked correctly can actually produce a finer grit edge than the number on the stone. Also there are burnishing effects from the metal in the paste scratching the knife’s edge, creating a shinier surface. The binder is also a softer abrasive, which tends to “polish the grooves”, and adds to the smoothness of an edge.
Shaptons are somewhere between the Diamonds and Choseras – they have a hard binder which scratches deeper, but they don’t load up as readily (in fact, using them clean is the best). The abrasive does not get released, and there is no interaction with the binder, which leaves perfect little scratches all lined up in a row, but without polish to make it “smoother”.
SO….
Diamond plates tend to make edges that are rather toothy and somewhat serrated. They pass hair cutting tests because the grooves cut into the edge are clean due to no breakdown. These edges are more aggressive.
Diamond pastes will still give your edge of the edge little serrations, which make it more “toothy”.
However when you switch over to Choseras, you still get some serrations due to the large grit size breaking off the bits of the thinning edge, but the overall surface is much more consistent. These edges are smoother.
Shaptons abrade things without polishing, so you get a very cleanly defined edge with grip.
The WEPS ceramics are similar to the Shaptons, but because of the loading up, will tend to polish the grooves more, leaving a clean, but not necessarily perfect edge.
Here’s a progression I did[/url] using the stock WEPS and the Choseras. You can see the differences between the diamond scratches (which are still good, mind you!) and the Chosera.
Here’s one using the WEPS 600 and the Shaptons[/url]. You can see the differences between the Choseras and Shaptons here (lighting is different, though.)
I hope this helps!
:blink:01/18/2012 at 12:34 pm #1386See what I told you Doug! The guy is a veritable encyclopedia on sharpening!
Good stuff Tom! Many thanks my friend!Leo
01/18/2012 at 3:55 pm #1388Well, I forgot to answer the ZDP question
ZDP-189 – As far as I know, it is an extremely hard steel, RC 64 and abrasion resistant, so I’d go with diamonds all the way.
This is where things get even more fun. I’m not a dedicated steel junkie, so please bear with me if I mess up some of the finer details.
You have hard steel, and then you have abrasion resistant steel.
Hard steel is a result of heat treatment of a given steel, which varies greatly from knife maker to knife maker. Rockwell 60 and below is considered softer steel, and Rockwell 60 and up is considered hard steel. You can loosely apply 1/10 of the RC hardness to the Mohs scale directly, as most conventional steel is between 5 and 6 on the Mohs.
The factors that influence which sharpening medium to use here are based upon the corresponding hardness of the abrasive. Diamonds are 10 on the Mohs scale, and abrade all knife hardnesses (so far!). Silicon Carbide and Aluminum Oxide (which Shaptons and Choseras use) are in the 9’s and can abrade steel every bit as well, so there is really no surface issue with these types of abrasives cutting into RC 64 steel. Sandpaper is usually feldspar, quartz or emery, which averages in the 6’s on the Mohs, so there is definitely some more “evenness” between the fight of steel vs. abrasive scratching action, which can be positive in certain applications, mainly surface polishing.
The binding agents play a larger role here in determining which brand of abrasive medium to use. The general rule of thumb is a harder steel needs a softer stone, and a softer steel needs a harder stone. The softer stone allows for more abrasive to be released, thus cutting more effectively into the harder steel. On softer steel, you can easily cut through the steel with the abrasive relatively intact, so there is no real need to release abrasive at a high rate.
Diamonds negate this theory, since they still cut through everything, but then practicality enters the equation – do you really need diamonds to cut a RC55 steel? Not really, it’s a little overkill, but at the same time, there is no need to ponder if it will sharpen a certain steel type.
Abrasion Resistant steels pose different problems. These use more exotic materials, usually powdered steels, which when treated, form certain carbides in the steel. Most Carbides are generally in the 9 range on the Mohs, so we have a serious competition happening for scratch ability now. Ironically abrasion resistant does not equal “Hard” as in RC 90. Because of the powdered steel, the hard carbides are essentially embedded in a matrix of “softer” steel, which can be as low as RC 55-60. On most conventional sharpening stones, you can abrade the matrix enough to produce “carbide popout” which essentially gives you a serrated edge where the carbides literally fall out, not abraded through. You can still polish the bevels, although going is very slow to get through the carbides.
Diamonds cut through everything, and on abrasion resistant steels, they are king for doing any profiling or serious repairs. Keep in mind that the fight is still there….
Bringing these abrasion resistant steel to higher refinement is also tricky – it is subject to carbide popout as you make the edge of the edge too thin for the steel to hold the carbides.
Anyway, I’m starting to ramble…:whistle:
01/18/2012 at 4:57 pm #1389Tom, thanks for the excellent and informative answer!
It sounds like ZDP-189 and other abrasion resistant steels might best be tackled with the WEPS by using the diamonds down to 1000 grit (7 micron) and then the 5 and 3.5 micron strops. Perhaps adding the 1 and .5 strops for a really fine mirror.
Would going “diamond all the way” like this reduce the chance of carbide popout? Because the diamonds would have a lesser chance of abrading the different hardness’s unequally? And perhaps the strops (as opposed to stones) would lessen the chance of carbide popout?
Or do I have it all wrong?
