how to clamp down medford infraction in the vice
Recent Forums Main Forum Techniques and Sharpening Strategies Tips for Specific Knife Grinds and Styles how to clamp down medford infraction in the vice
  • #53549
    Franky4246
    Hi wicked edge forum
    I have hard time trying to figuring out on how to clamp down a medford infraction into the vice securely, due to its shape. Wondering anybody can give me some pointers and advice
    Thanks in advance
    #53550
    Can you disassemble the knife and then clamp on the flat section where the pivot is located?
    #53551
    Franky4246
    Disassemble medford knife=warranty void…. so that’s a no
    #53557
    Wow, that is an unreasonable policy in my opinion.
    I think you should still be able to clamp this knife on the flat area in front of the stop pin. There might be a portion of the jaws that aren’t able to grip anything (in the thumb hole area) but that shouldn’t prevent you from being able to sharpen. If all else fails you can always clamp the knife in the Tormek small knife adapter and then mount that on the WE.
    #53558
    Franky4246
    they make great knives but policy is their right to reserve.
    I’m trying to see if someone had the. same knife and how they got it done……
    #53560
    Franky4246, welcome to the W.E. forum.  I have no experience with that specific knife so I wouldn’t profess to know how to clamp and sharpen it.  I can share with you with a few years worth of W.E. knife sharpening under my belt that:
    1. You don’t need to have the knife positioned within the jaws and resting down on the depth key pins.  The pins are simply a positioning guide that holds the alignment and advanced alignment guides positioned for recording the knife’s clamped position.  The knife can sit down on one or both pins, or neither.  As long as the knife is held securely between the vise jaws it doesn’t matter how the knife is positioned.  All we need to do is position and clamp a knife so it is tight and secure, and the position allows us to sharpen the knife edge.  Sometimes this requires that the knife be clamped at unexpected positions and rotated at unexpected angles.  Like I said, as long as the knife is secure and the stones can contact the knife edge at your desired sharpening angle is all that matters.
    2. Also, I usually employ a small rectangular patch of dry real leather chamois cloth between the jaws and the knife steel.  The chamois I find compresses tightly to allow for me to clamp knives tightly and securely for sharpening.
    #53561
    Franky4246
    great advice, and very welcoming, I hope I can clamp it on the hollow grind securely since I got a we120
    #53590
    Jeff
    Marc’s suggestion of using a small piece of leather chamois has served me well also on blades with weird geometry or a distal taper which can compound the issue where you want to clamp, however, in the picture of that knife the hollow grind appears to only go about 50% up the height of the blade around the mid point on the length of the blade.  Looks like there would be lots of essentially flat area above that to get an adequate surface to clamp on.
    #53591
    Franky4246
    I thought about it, just can’t decide which method I should go for, either the tiny flat spot above the main grind, or use chamois to fill up the thumb fuller,  and clamp on that…..
    IDK
