How fo view edge while sharpening??
Recent Forums Main Forum Techniques and Sharpening Strategies How fo view edge while sharpening??
  • #38648
    uilleann
    • Topics: 18
    My experience is from months of using the KME.  One of the things I would do is vary my strokes and pressure until I could see the previous grind marks disappear.  Its easy to do onmthe KME as you are lookimg down on the edge with the light shining on the edge.
    So now I have a new WE PP2.  Seeing the edge while I sharpen is less straight foward.  Any ideas or techniques?
    #38650
    Nicko
    • Topics: 11
    Stop and use a jewellers loupe or USB microscope?
    #38661
    uilleann
    • Topics: 18
    Yes that would work but its not as  efficient as looking at it as you do it……
    #38664
    • Topics: 82
    I have a bright LED over head light I work with and then pick up a bright little LED Flashlight to shine right on the side of my bevel to inspect it for scratches in the bright reflection. This works well for me. I also do use a USB Microscope connected to a little laptop that I hand-hold against the bevel to inspect in finer detail.
    #38669
    Pinkfloyd
    • Topics: 22
    MarcH,
    I use a Veho USB scope also, take a pic when I am done with each progression and compare pics to look at scratch patterns. Helps a lot.
