cbwx34 pretty much nailed the points I would have suggested, but it’s also important to keep in mind that when you have a clipped point type of profile and mounted horizontally, the distance from the vise to the tip can radically change the angle. That said, I think the position shown in your photos is actually quite good if your intent is to achieve a uniform bevel angle.
I will expand a bit on one of cbwx34’s points… The thickness of the blade at the bevel shoulder is almost always greater at the tip. To avoid weakening the tip, makers will chose to keep more “meat” in the spine near the tip. If the spine at the tip were as slender as the blade is thin at the bevel near the heel, the tip would almost certainly have a short life expectancy. Looking down on the tip, you’ll see the included angle and how the bevels are wider because of this. It’s this relationship which is requiring the removal of so much steel near the tip.
If you would rather duplicate the original bevels, consider moving the blade to a horizontal position. Moving the blade tip closer to or farther from the vise as you use the Sharpie method will let you match the bevel more closely.
