Grits / Microns
  • #11761
    Adrian King
    • Topics: 8
    While browsing the wicked edge accessory stones section I noticed one set of ceramics is listed as ‘Micro Fine – 1.4 / .6 microns‘ while the other ceramic is ‘Super Fine – 1200 / 1600 grit
    I was just wondering how these two stones compare, what micron are the the Super Fine 1200 / 1600 grit stones?
    Would this Super Fine stone fill the gap between the 1k diamond and the 1.4 ceramic?
    #11763
    Phil Pasteur
    • Topics: 10
    Unfortunately, there is really not grit rating on ceramics per se.
    I think that the ratings on the WEPS ceramics are sort of an approximation.
    I believe the manufacturers usually rate the ceramics using a surface roughness scale, not a grit rating.
    This is a quote from Sal at Spyderco (I believe that they source their ceramics from coorstec, the same place the microfine WEPS ceramics come from)
    “I would be curious as to where you got your numbers for the ceramic stones. All of the ceramics use the same micron size (15-25). the different grits are created by different carriers, different firing techniques and diamond surface grinding.
    sal ”
    http://www.spyderco.com/forums/showthread.php?31188-Ceramic-benchstones-compared-to-DMT-extra-fine
    Post number 7. Read the whole thread.. it is interesting.
    As to filling the gap, sort of. Many here say to use the 1.4 micron rated microfine, then the two super fine stones, then the .6 micron rated microfine. Some, Clay for one (I think) mentioned lapping the 1.4 to make it behave on steel closer to its rating. Do a search, I am sure you can find the thread.
    The above is the way I have been using them. It seems to work well.
    In any case, any grit rating is merely a reference number. What is far more important is what the abrasive does at the edge.
