Formation of Micro-Serrations – 800x
  • #4949
    This was a fun study to do – I started with a clean slate, a very highly polished (.25um Diamond on Kangaroo Strops) edge and then created a micro-bevel with the 10k Chosera Stones with 10 edge leading strokes:
    In this second image, you can see how smooth the surface is on the main bevel and at the shoulder of the micro-bevel.
    The abrasives hit the edge and begin digging a trough, immediately creating micro-serrations and continuing the scratch all the way to the shoulder. Were the strokes done edge trailing, the same effect would occur in reverse, still resulting in micro-serrations. I’ll repeat the study with edge trailing strokes soon.
    Next I flattened and re-polished the bevels before repeating the same procedure with the 5k Chosera Stones:
    #4952
    Here is the 10k Chosera again with edge-trailing strokes, both edge and shoulder:
    #4953
    Looking like edge trailing leaves a cleaner edge?
    #4954
    So far it looks that way, at least in the finer grits. I’ll post pictures of the coarser grits soon.
    #4960
    Here are some shots of the edge after the 100# diamonds:
    Edge-Leading
    (Looking straight down on the edge)
    Edge-Trailing
    And here is the edge of a blade at 30 degrees per side stropped on kangaroo to .25um:
    #4963
    I’m out of superlatives. Absolutely incredible.
    #4967
    Here are a few more –
    First I cleaned up the edge again:
    Then I did 10 edge-leading strokes with the 600# stones with very light pressure:
    Next I cleaned up the edge again and then did 10 edge-trailing strokes with very light pressure:
    #4969
    Here is the 600# edge trailing blade looking straight down:
    #4971
    I don’t see a clear winner at the 600 level…
    Love the straight down view. Pretty cool how fine an edge you can get at that level. 🙂
