Correct beginner stone/grit progression?
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Basic Techniques and Sharpening Strategies › Correct beginner stone/grit progression?
- This topic has 13 replies, 7 voices, and was last updated 06/08/2013 at 10:00 pm by
Ken Buzbee.
06/07/2013 at 4:28 am #12065
Hello all,
This is my first post. I just ordered the WE basic and some extra stones and was hoping for some feedback whether my choices are okay or not.
Below is what I have coming:100/200 diamond
400-600 diamond
800/1000 chosera waterstone
1200/1600 ceramic
5/3.5 diamond balsa stropsAm I missing anything? Is the grit progression and types of stones okay?
Thanks for your help. I feel like a kid before Christmas waiting on these.
Chris
06/07/2013 at 6:04 am #12066Congrats & welcome!
You’ll be fine.
General recommendation is to drop back a grit moving to the Choseras eg 600 diamond->400 Chosera-> as the diamonds cut deeper scratches.
But it all depends on what you want… Many here are OCD about getting the most polished bevel they can. When you think Chosera think “polish” so going back a level helps to remove those deeper diamond scratches.
But you can still get nice and sharp without that level of polish.
As to the ceramics, I very much prefer the micro fine and would have picked those over the 1200/1600.
I tend to go diamond 100…->1000->micro fine-> 2000 Chosera->and up if I’m polishing an edge that fine.
Ken
06/07/2013 at 7:15 am #12068Below is what I have coming:
100/200 diamond
400-600 diamond
1200/1600 ceramic
Welcome to the forum.
Looks good… you can work with this setup for a bit, give your diamond stones a chance to break in, and then decide if you need (or more likely want) anything else.
Have fun!
06/07/2013 at 4:30 pm #12076The stone that would be the next I line (at lest for me) in your setup would be the 800/1000 weps diamond. For me that one is invaluable, is you’re not going for polish it gives a great toothy working edge and to be able to move to higher grits it is also good for removing scratches.
06/07/2013 at 5:24 pm #12077Welcome! Exactly what I started with, with the exception that I started with the WE 800/1000 diamond stones. Your setup should work fine. However, be aware that the Choseras are very nice stones and they work addictively…
06/07/2013 at 9:56 pm #12087The stone that would be the next I line (at lest for me) in your setup would be the 800/1000 weps diamond. For me that one is invaluable, is you’re not going for polish it gives a great toothy working edge and to be able to move to higher grits it is also good for removing scratches.
Glad you added this, I saw 800/1000, and my mind interpreted he already had them (even though I read Chosera too).
This stone will also save wear & tear on the Choseras.
06/08/2013 at 4:45 am #12094Thanks Guys! I really appreciate it. I just ordered the 800/1000 diamond. I guess I should have asked my question prior to ordering but I am a bit impulsive. Below are the stones that will be arriving soon.
100/200 diamond
400-600 diamond
800/1000 diamond
1200/1600 ceramic
5/3.5 diamond balsa stropsI understand now that the diamonds will cut deeper so following up with a coarser chosera is appropriate. Does it make sense to follow 800/1000 diamond with 800/1000 chosera?
Also, I am not sure that I fully understand the Ceramic vs strop. Looking at the grit comparison chart the 1200 ceramic is the same grit size as the 5u diamond paste, 5. The 3.5u diamond paste is 3.5 while the 1600 ceramic is 2.85. What would be the progression here and why?
Thanks again!
06/08/2013 at 5:17 am #12095I don’t think there is a short answer here, other than grits ain’t grits. Despite having similar grit sizes, different materials will perform differently. Some materials break down into smaller sizes and have more of a polishing effect. So the extent to which a material maintains its original shape / size will make a difference on the sort of edge it produces.
That’s the very basic gist of it. Lots to consider here.
http://www.wickededgeusa.com/index.php?option=com_kunena&func=view&catid=14&id=5051&Itemid=63
06/08/2013 at 6:20 am #12096Also, I am not sure that I fully understand the Ceramic vs strop. Looking at the grit comparison chart the 1200 ceramic is the same grit size as the 5u diamond paste, 5. The 3.5u diamond paste is 3.5 while the 1600 ceramic is 2.85. What would be the progression here and why?
Thanks again!
Remember ceramics are hard. Their grits are fixed into this surface. Strops are soft. The grits bury into them, exposing only a very slight bit. So you can have a large grit in a soft strop but only exposed 3% it will yield much finer results than the grit would indicate.
Ken
06/08/2013 at 9:00 am #12097Hi and welcome,
I use that same progression quite a bit. Though quite often I don’t worry about the ceramic stones.
I think that you will like your edges …06/08/2013 at 9:08 am #12098Also, I am not sure that I fully understand the Ceramic vs strop. Looking at the grit comparison chart the 1200 ceramic is the same grit size as the 5u diamond paste, 5. The 3.5u diamond paste is 3.5 while the 1600 ceramic is 2.85. What would be the progression here and why?
Thanks again!
Ken[/quote]
To add just a little to what Ken said.. The “grit” in stones is much more concentrated than you can get… no matter how much abrasive you put on leather. They will cut much faster. Stones are for sharpening… strops are for… well stropping
Think of stropping as a sort of final polish or micro-refinement, rather then removing metal as with the stones. This is a simplification, of course… but it conveys the basic idea.
06/08/2013 at 9:22 am #12099Great point Phil!
Ken
06/08/2013 at 9:27 pm #12111Thanks so much everyone. Seems like a great group here, very knowledgable and helpful. I have a much better understanding now. Still a lot more to learn but I think I’ve got a good start. I’m looking forward to getting started and delving deeper into this.
06/08/2013 at 10:00 pm #12112You’re off to a great start.
But beware, you’re right at the mouth of the rabbit hole
Enter and there is no coming back
Ken
