Broadhead Sharpening Jig
Recent Forums Main Forum Welcome Mat Broadhead Sharpening Jig
  • #30139
    CJB
    <p style=”text-align: left;”>Hi Guys</p>
    Has anyone got any tips for sharpening twin bladebroadheads.
    #30152
    CJB
    <p style=”text-align: left;”>No bow hunters then?</p>
    #30154
    You might have to wait until one happens to check in.  There’s a limited number of us who check the forum daily, but there’s quite a few who stop by every now and then.  I really expect Clay Allison to chime in on this one.  I’m sure he’s done it.
    Not being a bow hunter myself and assuming you’ve already failed at clamping in the base vise, I would think that you’d be able to clamp most fixed, two-bladed heads in the Low Angle Adapter – maybe with the point of the blade extended off to the forward side, depending on the shape of the blade.  You’d only need to clamp at the very back of the lower edge.  This would expose all or nearly all of the upper blade for sharpening.
    Edit:  Understand that the Low Angle Adapter as supplied (unless they’ve since modified the design), will not fit in a Gen 3 vise, which is a little wider.
    #30156
    Hey CJB,
    Which brand of broadheads are you trying to sharpen? I’ve had some pretty good success with a few models. If you can post a picture, that would be even better. Re the low angle adapter, it has been redesigned to fit the G3 vise.
    #30164
    Hey CJB:  It’s early on Dec 31st here, so Happy New Year down there in Aussieland!!
    #30535
    CJB
    Hi Gents
    I ended up making a clamp with a tapered edge.
    See prototype No.1
    20160105_183418
    20160105_183407
