Any point to addidtional passes once a burr….
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Basic Techniques and Sharpening Strategies › Any point to addidtional passes once a burr….
- This topic has 32 replies, 10 voices, and was last updated 01/08/2013 at 2:22 am by
cbwx34.
01/04/2013 at 1:55 am #8590
Hey Brian! Wanted to send this your way…. Hopefully it will help ya with some of your questions as you start out
Josh,
I watched both videos, interesting stuff. I would agree it is “possible” to get to the apex without forming a burr. The question is how do you know (other than experience) “how close” to get before actually getting to the burr? The problem would be if you stop way too early, and progress to all stones and not hit the apex you have wasted your time and have to start over. Do you look to leave just a tiny bit of sharpie mark? I would think if you are not at the apex by 400 or 600# you aren’t going to make it, the 800# and finer stones won’t remove enough metal.
I do agree it makes since not to burr with 50 or 80’s. I did this and have have some chucks (at 10X) I didn’t get out. I only saw these after the 1000# and didn’t feel like starting over.
I agree with a re-profile you will take some steel off, and also some length.
If you are a normal to light user stopping and light touch ups should be enough for maintenance. Unless you abuse your knives you shouldn’t need to go back to 100# and start over each time. Even if you did, and you keep the same angle the amount of steel removed should be minimal.
You are absolutely right Geo, I did a knife the other night and it is not practical to apex on anything past the 600 grit stones. I don’t think (although I may be wrong) that his point was not to get a burr at all, because then you wouldn’t know if it has been truly apexed, but rather to get a burr on the higher grit stones (like 400 or 600 grit stones). Yes, I just would “paint” the edge w/ a black sharpie once in a while and when it was almost gone but I still didn’t have a burr, I moved up to my 400 grit and apexed there. Seemed to work well!
Everyone tends to get obsessive about something when they get deeply into Something like sharpening.
I too watched both of the videos…again.I contend that just because somebody does a video on the Internet, it does not make them an expert!
The steel conservation thing is really a non-starter for most people. You would really need to reprofile a knife LOTS of times over lots of time for it to become significant.One fallacy in the video is this… apexing at a higher grit takes less steel off of the blade than doing it at a lower grit. Think about it, to get the edge to apex at a given angle at a given edge height, you need to remove the same amount of steel. If you do it at a lower grit, and are careful, it is simply faster.
I will have to respectfully disagree w/ you Phil. While I agree that just because someone does a video it doesn’t make them an expert, I believe that the steel conservation issue is a big one – even for beginners. I know this from experience… when I started out sharpening knives, I would sharpen everything I could get my hands on, and because I liked my knives razor sharp all the time, I would do it frequently… even my nicer knife ($200+). Because I didn’t understand steel conservation properly, I ground away way too much steel… much more than I needed to. This was because I was under the wrong impression that you needed to form a burr with the lower grits 100-200 and form one at each stone on up through the progress.
To me, it makes perfect sense that this method would remove less steel… The reason being because If I am not actually grinding steel away from the edge itself (i.e. before I apex the edge) and do not remove any steel until later in the process, then I will be conserving steel. This vs. forming a burr at 100 grit and each stone thereafter… if you do this then you will be removing steel from the actual edge at each stone vs. just your higher grit stones. Another thing as a beginner on the WEPS was that I did not understand the proper pressure I was to use, and would really bear down on the lower grit stones and form a huge burr. I just thought these videos were helpful for the beginner to give them a proper perspective on conserving their steel, especially when they start trying to do higher end knives… sure, when you are doing a $40-50 cold steel it doesn’t matter too much, but when you get into $1-2-or 300 knives, it starts to be more of an issue.
If you want to take all day to sharpen a blade, listen to what the videos say. If you want to get a knife just as sharp in a lot less time, apex, carefully, at a lower grit, again, carefully and just until you pull a burr on each side along the entire lenght of the blade, then alternate with your higher grits.
It doesn’t take all day… I just did one the other day and it took about the same amount of time, you just have to take a little more care at that transition point to make sure that everything goes smoothly. Now, do I always wait until the 400-600 grit to apex? No… but that is my goal at least, especially on my own knives =)
Now I don’t pretend to know it all, but the logical mis-steps in these videos are pretty easy to see. The steel saved (unless you might be sharpening an antique that will never be used and is irreplaceable) is not worth the extra time you will spend.
As I stated before, in most cases you are right, but it doesn’t take that much time. As a matter of fact, most people don’t get the WEPS for the speed, they get it for the precision and sharpness factor. If I wanted speed I would use my belt sander (which a good bit of the time, I do use actually lol)
[/quote]As a data point, I have never used anything more coarse than the 100 grit stones. When I went off on a bench stone buying frenzy a few years back, I got some very coarse stones. I never use them. Getting those 50 or 80 grit scratches out would be a nitemare for me…[/quote]
See, this principle also applies to the 100-200 grit stones as well… although the scratches aren’t as deep, they are deeper than the 400-600 grit ones. So you are disagreeing with me that if you apexed at the 50 grit stones it would remove more steel than if you apexed at the 200 grit?
Hehe, love discussing this! Please don’t take anything I wrote the wrong way… mean it all in good discussion =)
01/04/2013 at 6:05 am #8598I’ll pitch my two cents in with Phil I just don’t see a problem with using your 100 stones. Yes you are going to possibly take away a little more material BUT we all have a wicked edge and we ALL keep our notes of sharpening angles so you only have to form a bur once on your knife the entire time you own it for kitchen knives which is where this conversation started. You sharpen them at 40 inclusive and the next time you sharpen you go back to 40 inclusive and knock it out. Why is there a need to raise a bur if you already know your at the edge? Sharpie it and roll out.
Now if you are sharpening a $300 knife that is a different beast all together. Then your going to tape the spine and cover the pivot area and do all sorts of stuff to make sure you take care of that knife because it is expensive. If your already taking your time and doing all of that you can use your higher grit stones to form a bur or you can pay closer attention on your lowers.
On that same note if your sharpening your knife so much that you are wearing it down then you should:
A: Do better maintenance between sharpenings
B: Find the right tool for the job if your damaging your knife blade that much (or use a better steel)
C: Try using a convexed edge it lasts longer
01/04/2013 at 6:38 am #8599If you are in to steel coservation, that is great. I simply don’t care about it. I have knives that are 40 years old and have been sharpened countless times, they still work just fine. I even have a couple that, in my ignorance, I pulled a full flat grind…by hand, from the spine to the edge, and did that more than once..
They still have blade integrity and cut stuff very well. So I guess the question I have is, at what point does this “probelm” become significant? My answer is, in most cases, it never will.The bigger point I was trying to make is that you will not conserve steel by getting a burr, or hitting your apex with finer grits. It is a matter of geometry. Given a fixed blade thickness and edge height, and stone angle, you need to remove exactly the same amount of material to pull a burr no matter what abrasive that you use to get there. Granted, you could possibly overdo it faster with coarser grits if you aren’t paying attention. At this level of sharpening hopefully you are paying attention. As one progresses through the grits, the aim is not to remove significant amounts of metal, but to remove scratches and to refine the edge. If you are not getting to the edge with half of your progression, it simply will take more strokes to get the same edge refinement.
The only way I can see for this not to be true is if one goes way to far with the coarse stones…way to far!
A lesson we can take from this discussion, and the thing that started this thread, is that you do not need to pull a burr at each grit. The fact that one would feel that this was required and continue to grind away at the blade needlessly is something that I would like to help prevent.
I use the WEPS the way I learned from Clay and the other good folks around this forum. After this discussion, last night, I went and got out my Spyderco paramilitary 2 that I have sharpened with the WEPS. I fist reprofiled it to 18 degrees about 2 plus years ago. I have touched it up probably a dozen times. I took out another PM2 that is in the box, never sharpened. You cannot tell the difference in the blades by eye. It would take a micrometer to measure the differences, and then I am not sure that this would not be as much due to production tolerances than the amount of steel I have removed. At this rate, I figure it could be 10 years before I can see the difference… Maybe this illustrates why I am not feeling any urgency to conserve steel. It also illustrates why I simply don’t think that not apexing with lower grits will save any significant amount of steel to begin with.
You are right, this is simply a discussion. There is plenty of room for everybody’s thoughts and opinions.
I just like using facts and figures (geometry) if possible.BTW, you are also right about the belt grinder. My little Kalamzoo see lots more metal removal than my WEPS. Cheap sharpening for hire always gets done there.
Phil01/04/2013 at 8:29 am #8602I’m thinking the difference of opinions here is differences in thinking. Pulling a burr at low grits results in a larger burr which results in more steel being removed…which seems right but still pretty insignificant unless you’re doing it each and every time you sharpen, then I can see how that will quickly get out of hand. In that case, yeah I would be worried about steel conservation.
Does that make sense?01/05/2013 at 1:10 am #8613I said thanks xuzme720, but I think maybe if I explain my method it would be easier to understand my scepticism on the metal conservation theory. When I reprofile I work both sides alternating with scrubbing strokes until I feel the onset of burr formation. Then I go to sweeping strokes. I try not to get an asymetrical bevel, so I go from side to side checking for a burr often. I can feel even a slight burr, I never go for a big honking burr on both sides, just enough to feel it along the entire edge. In other words I am careful to not overdo it. I guess this results in the minimal amount of metal removal, but this is not the goal for me. The goal is to get a known apex along the entire lenght of the edge while keeping the bevels symetrical… in the fewest number of strokes. Of course technique is important. pulling a huge burr is a waste of time..and steel. Likewise is trying to pull a burr with each grit.
01/05/2013 at 2:15 am #8621I understood what you meant, since that is how I sharpen as well. If not identical techniques, they are very similar. I am still in the experimental stage as well so I also try other techniques as time allows, of course. In this way I can see what works best for me and my setup. So far, what seems to work best, and since we are talking about steel conservation, is apexing (pulling that first burr) with the lowest grit I start with. [For me it’s the 100’s if it’s a new, or new to my WEPS, since I don’t have the 60/80 stones. 600/800 if it’s trashed touch up and 1000/1200 for normal touch ups that have no major problems. Usually it’s just stropping though for upkeep and only going to the stones for those times that the strops don’t/can’t take care of the edge.] Once the first burr is consistent along the length, then it’s on to the higher grits with alternating strokes to both remove the scratches from the stone before and remove the burr as we go. Progress through the grits as needed and strop at the end. I’m also watching the edge for refinement as the grits progress. This is what works for me and it does not seem to be removing a huge amount of metal even after a few rounds on the beater testbed Gerber that I have reprofilled a few times. You cant even tell any change in the blade shape. I’m sure if I continue for a few years with this testing on the same knife I can get significant steel reduction in the blade, but for normal wear and tear, unless you’re abusing the blade daily, I do not see it as an issue.
01/05/2013 at 2:34 am #8623Great thread,,, I always like ones that make me think and rethink some of these concepts.
Didn’t want this point to get overlooked… Raising a burr with the 50/80g stones is counterproductive. These stones are so aggressive, they can actually chip the edge, which then has to be sharpened out.
Good points on all sides! Some sharpeners think if you’re trying to create the “perfect” edge, you should never raise a burr. The final stroke, with the finest stone, should just reach the apex. A zen “catch a fly with chopsticks” thing I suppose.
01/05/2013 at 4:18 am #8625I do agree it makes since not to burr with 50 or 80’s. I did this and have have some chucks (at 10X) I didn’t get out. I only saw these after the 1000# and didn’t feel like starting over.
Didn’t want this point to get overlooked… Raising a burr with the 50/80g stones is counterproductive. These stones are so aggressive, they can actually chip the edge, which then has to be sharpened out.[/quote]
Heh, you guys have thought more about this than I though Possible. Thanks all for the posts…
To tangent Slightly, since the above is on that, what’s the underlying purpose of the 50/80 stones then? I used them quite a bit on the last knife I worked on (http://www.amazon.com/Smith-Wesson-CKSUR2-Bullseye-Search/dp/B000UUTAQ0) ~ sharpie mark on the OEM bevel and passes with the 1000 showed that the edge wandered left and right.. so with the left stone I hit edge at the heel, bottom of the bevel about 2 inch ahead of that, back to the edge and back to the bottom of the bevel. I tried scrubbing it out with the 100’s to get both sides to apex but didn’t seem like I was getting anywhere after 20 minutes so I went to the 80. Another 30 minutes passed and the right side was good, but I had issues on the left and went to the 50 for about 10 minutes. I didn’t really care if I got all the way, I was just trying to get close. Turned out that I was able to keep the bevels mostly even (tip was slight bigger on the left, which was where I had the most issue).
Anyway, proper time/use for those stones? If I’d had to do that with the 100’s, I think I’d STILL be working on the knife. :whistle:
I did get it looking pretty though:
And the owner was happy, though he didn’t really give a crap about the looks… oh well.
01/05/2013 at 4:31 am #8627Brian,
I think the 50/80 stones are for rapid removal of large material. Lesson learned for me is I won’t apex with them for the sake of the edge. I will try to get “close” and stop, then get my burr with the 100#.
I use the 50/80 when I have a lot of metal to re-profile and the steel is hard to cut. I did a re-profile last night on 154 cm. The 100s worked fine and there wasn’t too much metal to remove. Other knives I would have been there for ever without the 50/80’s.
01/05/2013 at 4:38 am #8628Another answer to this “why additional passes are needed once a burr is formed” is if the bevel is not equal on both sides.
Maybe I am doing something wrong. On a re-profile I work 1 side until forming a burr, then work the other side. I find the 2nd side will burr slightly, but the bevel is still not cut down all the way the same as the other side. I keep working it down until it looks equal to the other side. After that both sides burr very easily and with a very large burr. Then I do alternating strokes.
How does everyone else re-profile, work 1 side all the way to a burr or work both sides a little at a time?
01/05/2013 at 5:46 am #8629For me, if you can see the difference happening while on one side, I’ll go ahead and swap even before I apex and work back and forth, not alternating, just keeping the bevel even, so I don’t have to remove more than necessary. Then it’s easier to get the burr and keep the bevels even and then work forward through the grits as normal.
I do plan on getting the 50/80’s for faster re-profiling when it’s needed, but the money is just too tight from the holidays…
01/05/2013 at 6:06 am #8630Another answer to this “why additional passes are needed once a burr is formed” is if the bevel is not equal on both sides.
As I wrote above:
I may be able to describe it better, but I guess you missed it the first time around….
So,
When I start to reprofile I mark with a sharpie. I work alternating sides with scrubbing and up and down strokes. You can see when you are getting close to the edge. Usually part of the blade will start to apex before others. I try not to pull a large burr in those areas. I work on the thicker areas individually, always alternating sides as I go. I am always mindful of the Ken Schwartz video where he shows that you can get an asymetrical bevel easily by just grinding one side more than the other, even at the identical angle. So I do what I can to grind the same amount on both sides. When I can get a full length burr on both sides with a few strokes on each side…at this time the bevels should be equal, (as long as you make a conscius effort to remove the same amount of metal from each side as you are reprofiling!!).. Then I make about 10 to 20 strokes on each side with a sweeping motion, just to clean things up. Then I move to my next grit.The concept to take away is that you should try to work both sides of the blade equally while getting to the apex. If you grind away at one side only and pull a burr, then go to the other side and do the same, you will end up with asymetrical bevels. This makes sense if you remember that while you are grinding away at just one side, you are thinning the edge. When you switch to the other side, it will not take nearly as much grinding to pull a burr.
PS: Maybe I should clarify alternating as I was using i. I did not mean alternating individual strokes, but alternating sides with multple strokes on each side, just attempting to keep the amount of material removed on each side equal. The idea being symetrical bevels once you apex the entire length of the blade
01/05/2013 at 10:11 am #8637When I say re-profile I mean I’m changing the bevel angle. Sometimes it’s drastic, sometimes subtle but always only to my own blades unless someone specifically asks.
I follow the same regimen you do, Phil, or at least close. I’m not sure if it’s a case of great minds think alike or we have the same level of OCD!01/06/2013 at 6:17 pm #8663Phil,
Thanks for the detailed post. I was doing the wrong thing when starting off a re-profile, working 1 side all the way then the other. And it is a slight mess to try to undo the uneven bevel. You confirmed my suspicion that I should have been working both sides evenly.
Your answer is completely clear.
What do you do in this situation? A re-profile of a factory edge, left is 20 deg, right is 22, i.e. the factory bevels are not equal and you want to go to 15? Do you work “equal” scrubbing strokes on each side, knowing that you will get to 15 degrees first on the left and just keep going until the right also gets to 15? Or do you give a few more strokes to the right? Such as scrub 4 on the left, then 5 on the right, repeat…
I am just assuming you would hit 15 degrees first on the left side (20 vs. 22), or I am wrong? Of course it depends on the knife. I am thinking the 22 degree side has more metal to remove ergo more strokes needed vs. the other side.
Do you have a link to the Ken Schwarz video? ===>> Found it. (Post #2149)
http://www.wickededgeusa.com/index.php?option=com_kunena&func=view&catid=6&id=2149&Itemid=63#214901/07/2013 at 4:46 am #8664The concept to take away is that you should try to work both sides of the blade equally while getting to the apex. If you grind away at one side only and pull a burr, then go to the other side and do the same, you will end up with asymetrical bevels. This makes sense if you remember that while you are grinding away at just one side, you are thinning the edge. When you switch to the other side, it will not take nearly as much grinding to pull a burr.
I’m not sure I totally agree with this. If you have an already symmetric bevel at 20 degrees, and wanted to reprofile it down to 15 deg. and worked on side at a time,,,, if you worked one side until you created a burr, then switched sides, and repeated, you would still have a symmetric bevel on both sides. Since you’re working from the bottom of the bevel up to the edge, the “center” never changes.
The opposite holds true if you’re wanting to do the opposite… go from 15 to 20 (which sometimes happens if, for example, you want to strengthen the edge. Then you have to pay attention to working both sides an equal amount, because you’re working from the edge down, and each stroke is moving the edge “off center”. (BTW, all my angle examples are arbitrary).
My experience has been, the bigger issue is that blades are ground asymmetric to begin with. If you sharpen a knife that has no edge, then “working until you create a burr” would put the edge entirely on one side. Unless a machine does it, these knives are sharpened more for “looks”,,,, so while I’m sure an effort is made to keep both sides the same, in the end, looking equal is more important than being equal. So the result is, you have a knife with two sides sharpened at different angles, and/or with an offset blade edge.
Take a trip to a knife store, or look at knives you haven’t sharpened yet, and it’s easy to spot. The bevels may look the same, but look straight down on the blade at the heel, or straight down on the spine at the tip, and you’ll see how uneven a lot of knives are.
Then, along comes a sharpener that has the capability of keeping both sides the same, (doesn’t even have to be a Wicked Edge), that is reprofiling or even performing a first sharpening, and the problem now presents itself… by “cleaning up” the uneven angles, and/or the edge offset, you now have a knife that looks uneven, though now it is closer to actually being right.
So, you can’t say “work both sides the same” because if you do, and the blade has issues to begin with, this won’t correct them.
I think the biggest solution is to just pay attention. It is good not to just work one side entirely, but to occasionally switch, especially on a major job, so that you can see what’s happening. If one side is becoming larger, then work the opposite so in the end, they’re the same. The second part is, you don’t have to clean this up in one sharpening. For example, if I sharpen a knife, and in the end, it’s a little offset, but now sharp, just make a note of this. The next time you sharpen, maybe work the smaller side a bit more. Eventually, it will even out. The same holds true even for just a sharpening, look at the blade before you start, and if it’s offcenter, then work the side that will center it first, to help line everything back up.
A little sidebar… I’m pretty sure the video Ken made, has more to do with a debate on sharpening Japanese blades (some of which are stated to be sharpened at a “70/30” or “80/20” ratio)… whether they’re sharpened at the same angle on both sides, with one side more than the other, or if they’re sharpened at different angles to achieve the ratio.
