Any point to addidtional passes once a burr….
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Basic Techniques and Sharpening Strategies › Any point to addidtional passes once a burr….
- This topic has 32 replies, 10 voices, and was last updated 01/08/2013 at 2:22 am by
cbwx34.
12/31/2012 at 8:12 am #8465
is established?
I’ve done 10 knives now (all kitchen, only one of any quality), am quite happy with the results I’m getting. But I started noticing that once I get a burr with the 100 paddles, it only takes a couple swipes with the 200~600 to raise the burr again. Is there any benefit to doing more than the absolute minimum?
And my vise is now “scuffed” in on the right side. Oh-well, used is used. Guess I should have shimmed up that boning knife.
I love shaving off little curly cues from paper with these knives. No newspaper or phone books here, but normal printer paper easily push-cut on the knives in the vise after the 1000 grit plates.
12/31/2012 at 9:01 am #8466If you’re apexing (burr formed) you’re fine. The only reason to go further is to remove more, deeper scratches, on the way to a cleaner bevel (polished)
Ken
12/31/2012 at 9:05 am #8467To my understanding, no need to raise a burr after that. What you are wanting to do after you’ve apexed (raised a burr on both sides) the edge, is to refine it with your finer grit stones. You are smoothing/polishing the edge as if going thru finer grades of sand paper when working with wood. You are getting rid of/ reducing the scratches left by the previous stones.
Hope that helps12/31/2012 at 9:51 am #8468No, and to take it one step further: I try to stop short of raising a burr, in order to conserve as much blade life as possible.
12/31/2012 at 10:23 am #8469Very good, thanks. Kinda hard to Not raise a burr with the 400, I think it was there after 1 pass. Hadn’t considered blade life.. but I’m sure less material is being removed with the WEPS than my dad removed with stones, and the worn knives they had were hand-me-downs from Their parents.
I have a few of my Father-in-laws pocket knives that I’m going to work on next. I’m going to focus more on how the finished product looks with these, so I’ll pay more attention to scratch removal. I honestly wasn’t worried about the form/looks with my kitchen knives, just the function.
Thanks again though…
12/31/2012 at 2:59 pm #8479Brian,
Yes, there are special cases where more strokes after raising the burr is required. This happened yesterday to me. I had a burr along the entire edge, but one section still did not have the angle (profile) as the rest of the edge. I kept working on scrubbing strokes on this one area to get the bevel to look the same all the way down the edge.
My progression is:
With lowest grit stone I plan to use (50, 80 or 100), raise a burr 1 side with scrubbing strokes (and be satisfied with the bevel)
Use edge leading strokes opposite side to remove burr and then scrubbing strokes to raise burr other side.
Remove burr from 2nd side.
Start with alternating strokes (same stone), reducing pressure to refine edge.
Go through all other stones, alternating strokes (not raising a burr any more).
Check edge every other stone or so stone with angle cube and loupe to make sure nothing has changed. (at first I wasn’t tightening my screws enough).I found I was forming a burr with the 200 stones, especially if I did 2 strokes per side. I lightened my pressure and this mostly eliminated the burr. From 600 I don’t really notice a burr.
12/31/2012 at 3:14 pm #8480Once you put a burr on both sides, you will always alternate strokes with the finer grits. You may pull a small burr after each stroke, but not enough to matter, as you will remove it with the alternating stroke. As your grits get finer, the tiny burr after each stroke will be reduced in size. When you get to your finest stones, finish with very… very light strokes. Then strop very lightly… if you have strops. This runs counter to some of the thoughts about stiction changing the edge, but it works very well for me. Of course you don’t want to over strop, but experience will teach you when enough is enough.
If you can feel a burr after alternating extremely light strokes with your finest stones… you have a few choices. First, work on your technique, get some finer stones… or use one of the burr removal techniques.. Use a high density felt block or soft wood and draw the knife through it a few times until the burr is gone.
With very light alternating strokes to finish, I really can’t normally “feel” a burr after the 600 grit diamonds. I am pretty sensitive to this and can reliably feel this kind of difference in edge symmetry (micro burr..)even with hand stropping with 1 micron CBN on leather.
I also have never been able to get an edge at all by trying to stop before I pull a burr. I have read lots of folks that say they can. I don’t know how. At some point, when you sharpen to the edge of the edge, as you have to do to get something sharp, you will, at some point, end up with some kind of (even if only micro) burr, until you remove it with subsequent sharpening/polishing/stropping.
01/01/2013 at 12:09 am #8484…at first I wasn’t tightening my screws enough.
Heh, glad to know I’m not alone here. I’ve had the arms come loose twice. I even put on some blue Loctite in hopes that would firm up the screws, but to no avail (the clearance is too sloppy). I’m going to try some Teflon tape to see if that’ll fill in the space some and give the screws a little more holding power.
Okay, that, right there, is the piece of information I’ve been missing. The last videos I watched were from Smokeeater908 (or something along that line) and he did scrubbing strokes right through all the diamond plates. I followed because it’s stupidly easy for a nooB to replicate that, switching to (very slow) alternating strokes on only the last of the 800 and the 1000 ~ which are the final plates I own.
I did reduce pressure about 1000-fold between the first set of knives and the 2nd set, with outstanding results. I’m using such little pressure that some strokes kinda skip on and off the blade. I’m not sure how I could go any lighter on the pressure… though time/experience will certainly show me. 🙂
So, today I’m doing 4 pocket knives. I’ll get the burr and set the profile, then switch to alternating strokes with every other plate. That begs the question, when is enough? Is that where visual inspection comes in, to make sure all the scratches are uniform in size/depth? Might need to get on ordering that loupe…
Thanks again… you folks are the anti-thesis of most forums I visit (helpful instead of snarky).
Brian
01/01/2013 at 1:08 am #8486Visual is good, but one thing that hasn’t been mentioned in a while, is if you pay attention to both sound and feel, you’ll get clues when to switch. It took me a while to pick this up, but as you switch stones, moving to a finer grit, the stone, after X number of strokes, will make a distinct change, both in feel (almost feels like they’re not cutting, even though of course they are) and in sound, it will get “quieter”. Once you detect this, you’ll find it’s pretty easy to tell. I say “after X”, because it varies with the steel and grit level you’re at,,,, sometimes after 10-20 strokes, sometimes it might be 30+.
As you move to stropping, visually and the finish you’re “after” is probably the best.
01/01/2013 at 3:32 am #8489Good point Curtis. When I “feel” that the current stone has changed in feel and sound I try even harder to lighten the pressure and do 5-10 more strokes then move on.
01/01/2013 at 7:44 am #8497…at first I wasn’t tightening my screws enough.
I use the purple “breakable” locktite. I put quite a bit on. It makes the set screwss pretty darn stiff. I use a small set of slip joint pliars to tighten them down. I can’t always depend on my hand tightening doing the job.
Everyone has their own technique but I have seen several videos online showing methods that I don’ like much. Scrubbing is the fastest way to remove material. Once you have set the bevel, it is kind of pointless. The only time I have done this is for scratch removal at finer grits, then finishing that grit with sweeping strokes.
Thanks again… you folks are the anti-thesis of most forums I visit (helpful instead of snarky).Pretty much everyone here just wants to help. Let us know how your progress goes. I am interested…
01/01/2013 at 11:41 pm #8512That begs the question, when is enough?
It’s a great question, Brian and the post about sound and feel is spot on but in the end it all comes down to what kind of edge you like.
Some folks like to high polish everything (I find myself in this camp and really have to fight my OCD to not do this on every knife) Others like a really toothy edge and only run their knives to 600-1000 grit. Yet others try to get the edge they like for the task they see that knife doing. The more knives you do, the more you’ll figure out what you like for each given blade/steel/task.
Bottom line, there is no right answer to your question. The only absolute is to get to the edge and remove the burr. Once you’ve done that, it’s all preference from there.
Ken
01/02/2013 at 12:49 am #8514Hey Brian! Wanted to send this your way…. Hopefully it will help ya with some of your questions as you start out 🙂
http://wickededgeusa.com/index.php?option=com_kunena&func=view&catid=9&id=5360&Itemid=63#5407
01/02/2013 at 9:12 am #8523Hey Brian! Wanted to send this your way…. Hopefully it will help ya with some of your questions as you start out 🙂
Josh,
I watched both videos, interesting stuff. I would agree it is “possible” to get to the apex without forming a burr. The question is how do you know (other than experience) “how close” to get before actually getting to the burr? The problem would be if you stop way too early, and progress to all stones and not hit the apex you have wasted your time and have to start over. Do you look to leave just a tiny bit of sharpie mark? I would think if you are not at the apex by 400 or 600# you aren’t going to make it, the 800# and finer stones won’t remove enough metal.
I do agree it makes since not to burr with 50 or 80’s. I did this and have have some chucks (at 10X) I didn’t get out. I only saw these after the 1000# and didn’t feel like starting over.
I agree with a re-profile you will take some steel off, and also some length.
If you are a normal to light user stopping and light touch ups should be enough for maintenance. Unless you abuse your knives you shouldn’t need to go back to 100# and start over each time. Even if you did, and you keep the same angle the amount of steel removed should be minimal.
01/03/2013 at 1:35 pm #8577Everyone tends to get obsessive about something when they get deeply into Something like sharpening.
I too watched both of the videos…again.I contend that just because somebody does a video on the Internet, it does not make them an expert!
The steel conservation thing is really a non-starter for most people. You would really need to reprofile a knife LOTS of times over lots of time for it to become significant.One fallacy in the video is this… apexing at a higher grit takes less steel off of the blade than doing it at a lower grit. Think about it, to get the edge to apex at a given angle at a given edge height, you need to remove the same amount of steel. If you do it at a lower grit, and are careful, it is simply faster.
If you want to take all day to sharpen a blade, listen to what the videos say. If you want to get a knife just as sharp in a lot less time, apex, carefully, at a lower grit, again, carefully and just until you pull a burr on each side along the entire lenght of the blade, then alternate with your higher grits.
Now I don’t pretend to know it all, but the logical mis-steps in these videos are pretty easy to see. The steel saved (unless you might be sharpening an antique that will never be used and is irreplaceable) is not worth the extra time you will spend.
IMHO
As a data point, I have never used anything more coarse than the 100 grit stones. When I went off on a bench stone buying frenzy a few years back, I got some very coarse stones. I never use them. Getting those 50 or 80 grit scratches out would be a nitemare for me…
