Angles for butcher knives
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Basic Techniques and Sharpening Strategies › Angles for butcher knives
- This topic has 23 replies, 4 voices, and was last updated 07/26/2015 at 11:18 pm by
Leo Barr.
07/15/2015 at 6:39 am #25991
The work I do is meat cutting in a grocery store where my knives get heavily used every day on various meats. If I was to get a super low angle on my edge with a mirror finish will it last only a few minutes? My guess is that it will depend on the quality of the steel but I’m not sure if victorinox knives have the best steel in the world (I’ve been wrong before).
I’m probably going to be getting the pro pack II soon and I think I’ll be putting low angles on my pocket knives and higher angles on my butcher knives.
thoughts?
07/15/2015 at 5:10 pm #25992First time actually posting on here and I don’t know nearly as much as a lot of the other guys on this forum but just my two cents, if you really wanted to go super low angle, like 12-15 degrees, you would absolutely have to put a micro bevel on it at 20-22 degrees otherwise it would not last too long butchering meat through bone and what not. Victorinox steel is on the softer side of things but you don’t really want a super hard steel butchering meat, it’ll chip too easily. Anyway…. Hope this helps
07/15/2015 at 8:01 pm #25993with the work that i do day to day, i dont cut through bones with my knives. i only cut pre-packaged cryovac boneless pieces. if theres any work i need to do that involves cutting around a bone i use a backup beater knife for that.
07/15/2015 at 9:05 pm #25994As vono says around 15˚with a microbevel 20-25˚will suit admirable Victorinox is a pretty reasonable steel probable similar to A2. How the blade fairs is largely down to the way you use it if you find next time they need sharpening there are micro chips increase the main bevel angle say to 17˚.
07/15/2015 at 9:46 pm #25995should i even consider getting the low angle adaptor?
07/15/2015 at 10:29 pm #25996I do have the PP2 and as far as I can tell, it is able to do everything I need it do because of the riser block. I have sharpened my chef’s knife at 12.6 degrees with this setup. Just something to consider. This was on a Mac TH-80 which has a very hard steel on it so I was able to do this while still having it hold an edge for quite some time with everyday use.
07/16/2015 at 2:14 pm #26001Macs do have very hard steel which is fine until they need correcting either a wavy profile due to aggressive use of a steel or need for thinning.
I had one to do last week that was completely messed up the edge was so misshapen it looked like a butchers knife and the spine had been ground.this was one I had to reshape using my belt sander it probable took 20 minutes before it resembled a gyutu (that was after re grinding both the spine & the edge) I do not sharpen with a belt sander this I do on whetstones it still took a while since it needed thinning probable 8-10˚ before micro beveling.
It is a shame Macs are not laminated it would make corrective work much easier. Still the steel is good. I should have taken photos but it was part of a batch of knives I had to do and every minute counted . There was a yanagi which needed a lot of thinning and although laminated it was extremely tough steel & took 4 hours or more to do. That one I did photograph.Attachments:07/16/2015 at 7:01 pm #26002Wow… I am happy that I am the only one who uses my knife and I have not needed to thin it yet. My chef’s knife doesn’t look anything like the yanagi pictured but the blade is still pretty thin (2mm at the spine) and the actual bevel is crazy thin. Mine didn’t come with a 50/50 but instead with a 80/20 grind which was weird, but I’m not in a hurry to grind it down and correct it, although to do it properly on the wicked edge, I would need the low angle adapter for the factory 10 degrees and then the factory 15 degree micro… Oh well. It’s sharper than any other knife I’ve had unless we get into my super steel pocket knives haha
07/17/2015 at 12:30 pm #26004You may well find that if you look from the tip to the handle that the whole blade is from spine to edge off the centre line often asymmetric knives are.
My big thinning jobs were the result of someone just sharpening the edge and even increasing the angle . Provided on a thicker knife that the thinning bevel & the edge bevel are sharpened each time it should never be necessary to thin. I find on Macs for instance that once about 15-20% of the blade has been sharpened away it is necessary to thin. Often bad use of steels will require that once the waves are removed it is necessary to thin.
All single bevel knives should be sharpened from the shinogi and the the edge each time especially on debas that may be as wide as 5mm on the spine.07/17/2015 at 6:19 pm #26007You’re correct Leo, the only thing about this one is that is supposed to be a double bevel knife and sharpened on both sides, they just didn’t do that. It’s a Japanese made knife with a western style blade. I hope I’m saying that right… Hahaha
Austin
07/17/2015 at 11:00 pm #26011If it did have an 80/20 grind you can use the same angles each side just on the right side I would work that bevel almost through to the authorised then repeat the angle on the other side just enough to get a slight burr with luck you should have something like an 80/20 the other way to do it is count so 8 passes on the right to 2 passes on the left the idea is that the edge should be below your centre of effort so if the blade is offset then the bevel should be at the lowest point since the left hand side of the blade should be a lot flatter so the edge will be much closer to the fatter side.
I think I am probable succeeding in making it sound more complicated than it really is it is not an exact science the blade smith will not have sophisticated tools to set perfect angles so accept a sort of mas or menus approach to it the most important part is to have the same angle each side if you find it steers when cutting through a big melon note the direction it is going so if it is left there is not enough bevel on that side or vice versa I have not had to do this but I think that is the way it works certainly if you think about it say if it was a single bevel the knife would steer to the left on a deep cut since I think the bevel would eventually would try to run parallel with the cut I admit not been much of a melon fan I have not tried it either way you could prove this on a junk knife put a single bevel on it and see how it steers I would hazard a pretty good guess and say that if the knife tracks left then it needs a bit more bevel on the left to compensate . I am pretty certain I have it right please do correct me if you set up an experiment with a junk knife on a melon and find I have it the wrong way round I do like to see the mechanics of something over pure theory much easier too grasp.07/17/2015 at 11:19 pm #26012So I may or may not have had to read that Oh say a few times… But I think I do understand what you’re talking about. This specific knife is supposed to be 50/50 it just wasn’t ground correctly so I did take it to the weps and I corrected the bevel on it.
But thank you for the information on sharpening single beveled and knives with weird bevels on them! I appreciate itAustin
07/18/2015 at 4:35 pm #26013i think what im going to do when i get my weps is try to sharpen one of my work knives at as low of an angle as possible and see how long that lasts with my daily work load. then i might look into putting either a lower angle on the blade or a micro bevel set up.
07/18/2015 at 7:48 pm #26016I would start thick and go thin, once you thin the edge there’s no going back:)
Austin
07/19/2015 at 2:11 am #26020One thing to note micro bevels really do not take much to add to an edge you can create an almost invisible micro bevel just by doing 2 passes each side with your finishing stone when you have this the knife will cut as if it is a low angle say less than 15˚ or lower but it just makes the edge a little more robust I also then do one honing stroke on the micro bevel with either a 1K or a 600 grit just to add a little more bight to the blade.
