I’ve just loaded up my 5th knife, a Spyderco Brad Southard and am having a few problems.
Firstly I set my angles using the cube to read 14.50 per side and started with the 100 grit stones.
I seemed to be removing marker from the right places so moved to the 200g stone.
This is when I started to get problems with burr’s, one side seemed easy but the other was more trouble. I’d clear the burr and work evenly on each side for a while and try the burr again with the same results.
A couple of strokes on the right side would create a burr but when switching to the left side, many many were needed to create just a slight burr.
It was then I noticed the bevel was much larger on the left side, very noticeable by eye. I checked with the angle cube and they were spot on.
After some research I’m thinking the thickness of the blade is to blame but how do I set my angles to produce perfectly even bevels?
Although I understand only one side of the clamp moves I’m still a little confused as to why the angle should have to read different and what I should set the right side to, in order to match the other side.
