If you find your Knife Guide sticking with your WE20, try adding drop of lubricant to the guide track in the handle. A dry lube or silicon lube work great but most oils and greases should do the trick. Thanks to Doug Probst and several others for pointing this out.
Tiny drops of Canola Oil FTW! Worked for me.
