Wicked Edge - the Hot Rod Version
While playing with my AngleCube and the PP2 micro-adjusts one day, I came to the conclusion that my angle cubes (I have two, the Wixey and the older Igaging version) simply didn’t have the repeatability or accuracy to make the adjustments I was attempting. I had an idea pop into my head which wouldn’t seem to go away. The following is what happens when you have too much time on your hands and just enough money to tickle your fancies.
Don’t get me wrong… the AngleCubes are both plenty accurate enough for practical use, but this was an itch I had to scratch and had nothing to do with practicality. Plus I really didn’t like the fact that each time I moved the ball-joint micro-adjusts, I lost my ability to go back to an exactly repeatable angle setting used for a prior knife.
The idea of the thing was based on the hope that a screw adjustment (think ball screw or Acme) would provide rapid, repeatable adjustments with resolution exceeding the accuracy of the angle cubes. My original approach was to remount the rod pivot ball joints to blocks that would be threaded onto screws which would be mounted in the same position as the Base Rods. This seemed like the most elegant solution, but would require some form of bellows to protect the screw from filings and grit falling from the sharpening process happening directly above. Unfortunately, I couldn’t find a bellows out there that would fit my needs and fall into my budget. The cheapest one was about $35 and I would need four of them. Not to mention the need to provide mounting adapters.
This all drove me to the version you see in the photos below. I tucked the Acme screws up under shrouds and mounted the rod-end ball joints on stainless plates extending out from under the shrouds. The plates are silver-soldered to brass lead nuts, which are pre-loaded with jam nuts. To stabilize the plates, I installed guide blocks with slots a few thousandths wider than the plate material is thick. The rod-end ball joint fittings are mounted in simple straps of stainless bent with a mallet in my 4” vise. The straps are attached to the plates with Rhino CA glue. Everything you see here was done with woodworking tools - with the exception of a $50 DeWalt angle grinder I used to cut the steel.
The hardware from McMaster-Carr was $71 with shipping. I bought a 12” square sheet of 18 gauge stainless from Amazon – shipping included for about $22. The black parts you see are made from a section of UHMW plastic I had laying around. I have no doubt I could have made them to the same quality with some hard maple I have on my wood shelf. There are no bearings needed. You could add bronze bushings, but the screw shaft material spins happily in the self-lubricating UHMW. So I’m into it for less than a hundred bucks. And a couple week’s worth of spare time.
Next question of course is “Does it work?” In the first couple of hours after it was done, I was thinking I’d really gone over the deep end on this one and I’m going to be the laughing stock on the WE forum. I was absolutely flummoxed by the need to relate movement at the adjustment wheel with the angle of the stones. I was thinking that this was going to be one of those projects you hide in a bucket under your bench. But by the middle of the second knife, that problem (my brain’s eye-hand coordination) had resolved itself. Move the wheels up and away from you and the angle is reduced. Toward you and it’s reversed. Yes, one screw is right-hand and the other is left-hand. Sweet. I like it and I’m going to keep it.
I designed the assembly to keep the rod-end ball joints in their original axes and with the same 15-35 degree range of motion. The Acme screws are 12 turns per inch so each turn of the handwheel moves the ball joint 0.083”, for very close to 0.8 degrees angle change per turn. There is about 0.012” backlash when changing from CW to CCW or vice-versa. From a few tests I’ve run, if you approach a handwheel setting from the same direction each time, the position seems to repeat within +/- 0.005”, which is at least twice as accurate as my angle-cubes. If you make a 1/8 rev motion of the handwheel back and forth, you can see corresponding movement in the slide plate. This suggests that the pre-load of the lead nuts is working very well. The one area that needs improvement lies in the robustness of the straps supporting the rod-end ball joints.
What are the advantages? Making angle changes requires no tools and nothing is going to go out of adjustment (excepting mechanical breakage). Any and all settings are achievable with a single adjustment. In practice, once you have found your starting bevel angle, changes as small as 0.1 degrees are easy and repeatable.
Is this something you should do? Hell no. This was done for fun just so I could see if I could do it. It took about four times as long as I thought - mostly because I was working with materials with which I was not familiar. If you have a granite base, jump to another topic, quick. If I were so inclined, I’d make the version with a set of home-made bellows. This would eliminate most of the position error which is caused by the lead nut slop, amplified by the ratio of the plate length to nut radius. In an axially-mounted system, motion error would be limited to the axial position error of the nut. When I assembled the lead nut, jam nut and lead screw, there is absolutely no detectable axial play.
I haven’t yet had a chance to look underneath the deck of the new WE professional Series Sharpener, but I’m guessing there’s some of this in that. Now if I could just figure out how to incorporate Clay’s floating jaws. Hey Clay! What do you think about offering kits to upgrade us to the floating jaw?
So let the giggles commence!
That is awesome! Great job :slight_smile:
I am trying to engineer the floating jaws so they can be added as an upgrade to existing platforms.
Wow that some impressive handy work .
It seems a lot of people are pimping their WEs one way or another the floating jaws have to be the ultimate upgrade but I imagine the pivot point is wide and therefore the jaws would probable need some sort of well to sit in so the stone arms can get in close for the lower angles . Still perhaps we can see some more in depth pictures of them in the future.
Leo Nav
ONE KEWL HOT ROD FOR SURE
i like it… :slight_smile: :slight_smile: :slight_smile:
Thanks for the kind comments, gentlemen. I’m becomin’ quite partial to this little sweetie pie. I only wish you could take her out for a spin. Of course, I’d be fretting about gettin’ her scratched up.
I think I’m going to cerakote mine :slight_smile:
Great mods btw!! I love it!
Interesting setup. I have a question about the above quote though… If you look at the angle markings on the WE, the distance between the marks gets bigger the farther out you go. Does your setup account for this (or does it need to since I’m not sure exactly how it’s working)?
The Acme lead screw is a constant - each turn produces the same 0.0833" of change in the opposite side of the right triangle. I ran one of the screws all the way out to the end of its motion. The angle cube read 37.5 degrees on a blade sitting about 5/8" above the clamp jaws. I then made a five-turn change down from 35 dps and it changed to 31.55 dps. This works out to 0.69 degrees per turn - not a whole lot different from the 0.8 dps when making adjustments down in the 20 dps range. Certainly, the difference is something to be aware of.
I’m glad it’s got your interest though, which was the whole object of it.
Clay,
What do you mean by “floating jaws?”
What do you think about this?
[quote quote=“KnifeKnerdAtX” post=19891]Clay,
What do you think about this?[/quote]
We played with a design just like that a while ago. Instead, we’ve gone for another style. I’ll try to put up a video of the prototype on Monday. It’s working great so far. One change we might make to the prototype is to add the counter threaded screws at the top for thickness adjustment though I’m not sure yet about that.
I had been thinking about floating vises also.. something that can grab a full flat ground blade at the angle it is ground at and automatically center the blade per the grind in the vise. Everything I come up with would be too thick at the top lol.
I think you guys will like what we’ve come up with. I’m excited to do the video on Monday.
Monday can’t come soon enough!
Well. Now I am curious! Hopefully it allows for low angles!
My mind is racing!!!
http://youtu.be/YGlT0LtRzMw
http://youtu.be/itFsXPtNboA
Clay,
Any update on the video?
[quote quote=“pinkfloyd74” post=19964]Clay,
Any update on the video?[/quote]
It’s uploading now :slight_smile: As soon as the upload is complete, I’ll post the link.
So excited!!
Okay, here’s the link: http://youtu.be/3-YP9hnd6Nc. You’d think that I would know enough to hang onto the handle of the knife while releasing the lever… :oops:
That’s so awesome, Clay! I Assumed correctly in thinking you would use the professional series when coming up with ideas for designing the new clamp. I’m very excited to see where things go from here.
Thank you so much, sir!!!
