Wicked Edge Gen 3 Pro, 2017 model review
This thing is amazing… almost should be called gen 4 imho. Check it out!
https://www.youtube.com/watch?v=mPS8oec06a4
I know what I’m watching when I get home from work!
Thanks for the video Josh! I have one question; is the tension adjustment that raises / lowers the cam continuously variable between the two extremes, or do you have to set it to one side or the other? I’m looking forward to the retrofit clamp becoming available. Hopefully the pricing won’t hurt the pocketbook too much.
You can set it one extreme to the other or anywhere in between… At first I thought it was going to slip if set in the middle but that’s a non issue it turns out :slight_smile:
Thanks for the review (and for being part of beta testing!)
Now I can’t wait to receive mine.
Look forward to hearing your thoughts!
