I see by your photos and videos that like me, most of you also suffer from the occasional nick or cut visited upon you by the various knife-sharpening gods, while attempting to keep your attention. I wanted to share something that I’ve found to be quite effective in healing those wounds quickly.
Band-aid (run by Johnson & Johnson) has a product that they’ve been trying on the market. It’s a small band-aid which looks a little like a sanitary napkin with wings. The principle is to seal the wound off from the world and to let the healing properties of the band-aid do the work.
Yes, the band-aid has a border surrounding the absorbent pad and this border is meant to completely encapsulate the wound, protecting it from the environment. The absorbent pad is touted as having “advanced healing” properties and my experience would support that claim.
Unfortunately, J&J has not marketed a larger version of this band-aid in the country, Perhaps a manufacturing problem. I continue to monitor their progress.
Edit: I see a product listed as a large size now, but the name is different, so I can’t be sure that it’s actually the same thing in a larger size. I’ve ordered some and will let you know the results.
Before applying the band-aid, you scrub the area thoroughly with soap and water, ensure that the wound has stopped bleeding and wipe the area carefully with alcohol. The alcohol is instrumental in promoting a sound attachment of the adhesive by removing all traces of oil which might interfere with the formation of a good seal. You leave the band-aid on for at least a few days - it will survive multiple showers if attached securely. Like steri-strips, you can wear them until they fall off. They’re quite comfortable, even on finger tips and knuckles. As time progresses, you’ll see that the absorbent pad which was very thin before application, is now quite thick as it absorbs liquids which are produced during the healing process
When removing the band-aid, you’ll notice that the entire absorbent pad area seems to have attached itself lightly to the wound and the surrounding area. You’ll also note that the wound has progressed nicely (with no scab) and will dry out and heal quite rapidly. I usually get very good results after three days.
Try it. You’ll like it.
