[quote quote=“CliffStamp” post=14883]Thus if you do some experimenting you will find that the optimal geometry is the one which has just enough thickness to keep the knife from warping. If you go below this the knife will fail by warping that you will see. [color color=#ff0000]If you go above it then it will increase the rate of wear, deformation and fracture at the very apex[/color]…
Now as carbide volumes get high this means you have to take them into account because some steels have carbide loads which are so dramatic that if you under cut the steel and make it very thin there will not be enough steel to hold the carbides in place. It would be like trying to pour a slab of concrete 3" thick if you had 4" rocks in it. If you grind too thin for the carbides it is easy to see because the steel will just break apart. If you do it dramatically then it will form dramatic burrs in sharpening due to the heavy fracture.
This is a low carbide steel (5Cr15, 55 HRC):
vs a high carbide steel (S35VN/60 HRC, Peters):
Finished on the same stone to the same angle (<5 dps). Note how one forms very clean and the other clearly is fracturing readily. The stone was a 700 X Bester.
[/quote]
Ahhh that makes a lot of sense, thanks!
so what do you mean by having a thick-shouldered edge will cause it to "fracture"? I would think it would just wear away and become blunt, because the carbides would be supported in the wider steel matrix, right?
In your second picture, this is where the carbides in the steel have been ripped out because the dps angle was too low, right? Now… wouldn't the actual size of the carbides play a huge factor in this as well? Like s30v has very small carbides, which maybe could be supported in a lower dps angle, whereas D2 has larger, irregular ones so it could not? (I don't have the pics of each steel, but I have seen you post them before elsewhere)
