Technique Question
I get the impression most sharpening is done using each stone grit on both sides and progressing to finer grits.
Is there a reason not to complete one side at a time going from the first to last stone on one side then doing the same sequence on the other side?
[quote quote=“Bill Kirkley” post=23308]I get the impression most sharpening is done using each stone grit on both sides and progressing to finer grits.
Is there a reason not to complete one side at a time going from the first to last stone on one side then doing the same sequence on the other side?[/quote]
Theoretically you could, but the problems with that are:
  1. you will probably have uneven bevels
  2. large burr formation and over-stressed apex which will lead to a weakened edge
  3. problems w/ burr minimization
:slight_smile:
but you could work one stone for a bit, then use the other hand and work the other side with an equivalent stone for a while before moving to a finer grit - I do that all the time.
Josh is right on all counts.
I have a neurological deficit caused by non-opiate pain meds (tramadol), so I find it’s easier for me to do one side at a time. The left hand is fine, but the right works best if I can focus on it alone. I’ve had no problems working one grit at a time. When I get down to the highest grit I plan to use, I very carefully do alternating left/right strokes to remove the last bit of burrs.
Technically, I guess you could get by with one stone of each grit. Still better than a Lansky or Edge Pro - no remounting the blade.
Thanks guys. I tried it and as Josh pointed out there was a large burr opposit the first side I sharpened. When I finished I had a good edge but maybe it was weakened.
