SWAT ACCESSORY
Clay,
I apologize in advance as I know you must get tired of the question, but any specifics on when the SWAT Accessory will be available?
Thanks,
Mark L. Massie
Choctaw, OK
We finally got the latest prototype in and it looks great. I think we’re ready for production. I’ll announce as soon as we have pricing and a lead time. Photos to follow later today.
Here are a couple of pictures I just snapped of the new parts:
The only change I’m imagining now is to replace the thumb screw with a regular #10-32 socket head cap screw. The Allen key on the vise key will fit it and by not having the larger thumbscrew, it can get all the way up against the blue base for the smallest of angles.
Clay,
Thanks for the update and I believe the additional change you are recommending will be a much appreciated change. I realize this should probably be self explanatory, but can you provide a quick synopsis of how the system will work to confirm my understanding based on the pictures?
Thank you,
Mark
Clay,
Just looking at the picture, wouldn’t the width of the vice key become an issue with tightening the socket screw with the SWAT set-up for the sharpest angles?
Thanks,
Mark
[quote quote=“MarkMassie” post=15528]Clay,
Thanks,
Mark[/quote]
Mark, that’s a good question, I was worried about the same thing. I tested it out though and there is enough clearance. The perspective of the photo is probably a little bit misleading.
[quote quote=“MarkMassie” post=15527]Clay,
Thank you,
Mark[/quote]
SWATS have to be on the key stock. Find the angle you wish to sharpen at like you normally do and tighten in position as you normally would. Now, slide the SWAT over to where it meets the stone/paddle, and tighten at that position. Now you can make up for any difference in stone thickness when changing stones by simply loosening the angle arm clamp, and sliding it over so that the new stone contacts the SWAT, and retighten the angle arm clamp. No need to use the angle cube to keep stones at chosen angle.
Hope that makes sense
Clay,
Great news on the clearance of the vice key and thanks for the explanation as to how the SWAT will work. Your explanation is clear and is just like I understood the SWAT would work. I can’t wait for the product to become available. Thanks for all you and your team do.
Thanks again,
Mark
Hey Guys,
Sorry if this was mentioned elsewhere, but I missed this. What does this device do?
[quote quote=“Geocyclist” post=15548]Hey Guys,
Sorry if this was mentioned elsewhere, but I missed this. What does this device do?[/quote]
couple posts up:
[quote quote=“Mikedoh” post=15530]
Hope that makes sense[/quote]
I SO want this!
Ken
WOW :cheer:
That is brilliant. I am definitely up for that. This would also be good to check every stone. I know I “should” check every stone, especially the water stones as they may not all be 100% equal thickness (especially after flattening).
Looks nice.
[/quote]
I SO want this!
Ken[/quote]
Ken, the best way for you to get one, is to order two, and send me one. :slight_smile:
I too must have one!! :stuck_out_tongue:
[quote quote=“Mikedoh” post=15575][quote quote=“KenBuzbee”]
I SO want this!
Ken[/quote]
Ken, the best way for you to get one, is to order two, and send me one. :)[/quote]
Hey, if that’s what it takes! :wink:
Ken
Well, it may not take that, but IMHO, it is “the best” way.
Would certainly be thank’n ya.
