I can’t really answer the question of films vs. strops (‘cause I don’t have any films)… but I wanted to comment a bit about stropping with leather.
First… don’t be afraid of pressure. When I first started sharpening (this part was pre-W.E.)… I would take what I thought was a sharp edge, and strop it. I would find, as many do, that the strop seemed to “kill” the edge… often described as “rounding”, no longer has bite, etc. And the solution given… use as little pressure as possible. For me, doing this seemed to either still “kill” the edge, or result in no improvement… to the point where I didn’t bother.
But after watching numerous videos of people stropping, often with significant pressure and getting good results (Clay for example, use to report stropping with enough pressure he would start to lift the base)… I knew I was missing something. So, occasionally I would revisit it.
Over time, I found that stropping would improve my edge… and I didn’t have to use “light pressure” to get good results. I can now strop with pressure, make the occasional “greater angle” stroke, etc. and find that it usually only improves the edge. Why? Can’t say definitively, but my best guess is… it’s because I learned to create a proper edge prior to stropping (sharp and burr free). A proper edge will benefit from stropping, an improper one will often die. (I think another part is the right compound… “green compound”, for example, is no good for a sharp edge IMO).
The other thing is the convex part… (this is on the W.E.) So little convex is created… it essentially doesn’t matter. As a test this a.m. (just to make sure nothing cropped up)…. I created a flat bevel, then stropped the crapola out of it with the 10m/5m “regular leather” strops… with some pretty significant pressure (I have a panavise attached to a granite base, and was rocking the whole thing back and forth… so… pretty significant), and at the same angle. Then I remarked the blade with the Sharpie, and checked the edge with a stone… and the marker was removed along the entire bevel width in one stroke… and no convex detected under my handheld scope. Now, my strops are pretty old, and somewhat stiff (like my joints), so that plays into it I’m sure (I’ll spritz them with alcohol which over time also stiffens them up)… but like I said, I was stropping pretty hard, and detected no convex… none that I could tell anyway. (And I got a very sharp knife).
I do think you can create a ‘faux’ convex as stated above (multi bevels, then blend it with leather), but the stones do most of the work. Also, nothing wrong with using alternative media, as some have written…. for example, my freehand stropping is now often done on paper.
Anyway… my .02. Don’t take my word for it… take a beater knife and a Sharpie… and test some of it out. (Mark the blade between stones and strops, so you can see what’s going on). Maybe new leather will require a 1 deg. decrease in angle… but strops I’ve found are more forgiving than most assume… especially given the proper edge and compound to begin with.
