In my ‘welcome mat’ thread I mentioned that I have a ceramic with the stone mounted very unevenly. Since I was going on a mini-vacation to the warm temps of Tampa for a week, I put my ceramic an a solution of mostly Simple Green to soak. I needed to add a little water to get the level up past the tape.
It soaked for 6 days. Yes, Simple Green does dissolve the adhesive tape.
How many days do you need to soak? Not sure. But 6 sure did the trick.
So if you need to remove your stone, in my case a very brittle ceramic, Simple Green will do the trick if you can give it some time.
Cheers
Dale
