Scissor adapter problem
The Gingher brand scissors have an edge angle of 37-45 degrees. I mounted the scissor adapter on both the Generation 3 and standard mounts on my WE. The stone collides with the mount screw. Suggestions?
I tried a standard machine screw (10-32 5/8" long) in place of the thumb screw and it holds the scissor just fine. I have not tried it on the vice yet but looks like it might solve your problem. My wife has not let me try to sharpen her Gingher’s yet, I need more practice still.
Thanks I’ll try it. The max edge I can reach is 38 degrees. To achieve steeper angles I believe I’ll have to freehand, because the degree bar has limitations beyond that. Whats been your experience?
I played around a little. Got it to look like it is real close to getting the angle right. I moved the degree bar on the base. Hope this helps you.
