[quote quote=“PhilipPasteur” post=8343]Hi,
If you do a search on s30V Steel, as I have, I think you will find quite a few people that say the steel doesn’t take as good an edge, nor polish as well as some others. I have been playing with some knives with D2 steel at the edge. I had just sharpened a Spyderco Military in S30 V. I was very surprised at how much “apparently” sharper and brighter the D2 gets. I have found S30V does hold an edge quite well over time though.[/quote]
I just wanted to say that I have reconsidered the above. First I dragged out the Spyderco Military that I talked about and went over it again. I had reprofiled this knife at 18 degrees per side. I went back to the 800 stones, as Mike said this is where he started. I went through the 1000 diamonds and the ceramics. I did the ceramics in the order 1200, 1400, 1.4 micron and .6 micron stones. Since I resurfaced my 1.4 micron ceramic, this is how I normally use these stones. I put a fine burr on both side with the 800 grit stones, then ran about 50 strokes per side at each grit level.
I also have 1 micron an 0.5 micron diamond spray (from Ken Schwartz) on the WEPS cow leather strops. I dropped about .75 degrees to around 16.25 degrees and did about 100 strokes per side with both grits. I find the knife to be very sharp. It is not the sharpest knife I have done, but it easily shaves arm hair and push cuts phone book paper in both directions.
I also did some research. The last time I looked and the places I looked all had folks complaining about S30V getting a fine edge and taking a nice polish. This time, everybody was raving about how sharp they get S30V… and how well it keeps an edge… go figure. That will teach me to talk about ancient history
One thing that came up in more than one discussion was that the Benchmade S30V was harder to get a vey sharp edge on it than other makers. I don’t know why… bu that, according to what I read, seemed to be the common wisdom.
So Mike, how many strokes did you do per side. What kind of pressure were you using? Did you examine the edge with magnification to possibly see what is going on? Have you considered reprofiling to maybe 20 degrees per side? A more acute angle on the bevel will allow you to get the blade sharper (I know this is something else that can be discussed at length, but at any rate it can be proven that cutting effort will be reduced).
Knowing exactly what you did might let us make better suggestions about how you might improve your edge.
BTW, that D2 Kershaw is still “subjectively” noticeably sharper than the Military, and much prettier…
