Watch and feel to tell whether they are working to my expectations. Those expectations are based upon how they worked with a fresh coat of abrasive.
I clean with minimal alcohol and recoat. I only use the sandpaper when surface irregularities become an issue, or when an alcohol wipe just doesn’t get it. I have had lots of my strops in use for well over two years and lots of knives.. I have lapped them once.
If they are solid black… well it probably means a bit of cleaning is in order. Of course, after cleaning you need to recoat them.
That is for leather. I don’t use my balsa strops that much. When they need attention, I will likely follow the same protocol.
[quote quote=“PhilipPasteur” post=11327]1. Watch and feel to tell whether they are working to my expectations. Those expectations are based upon how they worked with a fresh coat of abrasive.
That is for leather. I don’t use my balsa strops that much. When they need attention, I will likely follow the same protocol.[/quote]
I’ve just reloaded my strops, and it does make a huge difference. I wasn’t able to get them completely clean though before reloading them. I just made sure that I put the same paste on each one.
Phil, you can lap the leather w/ sandpaper? I didn’t know that…
Phil, I highly value your opinion on this forum, so I am very curious as to why you don’t use your Balsa strops that much ? For me personally, I prefer those over the leather one by a large margin…just something about the feel of them on the blade for me, the sponginess of the wood, and the less drag with them as opposed to the leather ones ) I feel like, for me anyway, that they are more controllable ? :unsure:
You know, I am not sure that there is a real definitive answer to the question. It is more a situation where I use what I have that works. I only have two paddles with balsa mounted on them. So that is 4 grits. When I got them I loaded them with the abrasives that I had. I used 3M pastes on them, which I found I am not all that fond of. As my collection of strops grew I focused on leather, mostly because I had lots of different grades on hand from making bench strops over the years. Further along I learned about Kangaroo and nanocloth. Now I have all of my sub-micron pastes on these strops. So I have different strops with horse butt, and different grades of (and tanning methods) of leather for the coarse pastes and sprays and the finest stuff on the 'roo and nano. I guess that with all of that going I just don’t reach for the balsa strops that much, if at all. I suppose I could clean them up and apply some better abrasives, but I haven’t seen the need. I guess this kind of thing happens when you have far more tools than you really “need” for a given job.
I suppose another part of this is that I am a creature of habit. I get something that works for me and I tend to stay with that until something comes along that is just so much better that it forces me to change things up. The bulk of the sharpening that I have been doing lately fits the pattern nicely. With limited time these days to devote to experimentation … I just do what I do well and call it good.
Not very adventuresome, but expeditious…
:ohmy:
So, it is not that I find anything intrinsically “wrong” with the balsa strops… I simply don’t use the ones that I have. As usual, if you find that they work well for you, I wouldn’t want to say anything that would discourage you from using them. That being said, if you get a chance to try some Kangaroo or, especially nanocloth (I think I could use these for all grades of abrasives and never look back!), I think you would be very happy with the results!!
Thanks for replying Ken..OOOOPs, I meant Phil, sorry, had Ken on my brain I guess…I actually just got in yesterday some of the WEPS Nanocloth platens from Ken Schwartz and some of his 4 micron CBN spray…can’t wait to try them out.
Short update from me. I reloaded some leather strops the other week. I cleaned with alcohol first then loaded paste. I let them set 24 hours before using. I moistened with alcohol before use (I always do this). Results were good. I could feel “more grip” of stiction.
Lately I have used both stops and balsa. I have duplicate sets in the low grits (14 to 0.5 micron). I start with 14 m balsa, then 14 m leather, 10 m balsa, 10 m letaher… I use the same angle on both which is the same angle used for sharpening. Doing this I don’t go super hard on the leather. (when I want to go hard with leather I drop the angle 1 degree). The balsa flexes less and feel more like a stone. I don’t have a microscope. I can say the edge is very well polished, but it may just because in total the edge gets so many stokes.
I believe Phil said this, that he sometime uses only 5 and 3.5 stops. I have done this on EDC’s when I don’t want to spend the time. I find I get good results with this. It also works for touch ups too. If I only had 1 set of strops it would be these in leather.
:ohmy:
So, it is not that I find anything intrinsically “wrong” with the balsa strops… I simply don’t use the ones that I have. As usual, if you find that they work well for you, I wouldn’t want to say anything that would discourage you from using them. That being said, if you get a chance to try some Kangaroo or, especially nanocloth (I think I could use these for all grades of abrasives and never look back!), I think you would be very happy with the results!![/quote]
So what’s your favorite strop (other than nano and roo)? i’m looking for a cheap but good alternative to re-do a few of mine… have been researching oil tanned, veg. tanned, etc. I want something that holds the compound well but is not rock hard either. some type of leather like is on my straight razor paddle strop.
Darrell, For what it is worth and that’s not much? :lol: I really like the balsa strops as well. If you get some spare coin try the 14/10 balsa. I was amazed at what a difference they make before using other strops or by themselves? I also really like the way they feel.
thanks Eamon…the 14 / 10’s are next on my list for sure. B)
On a little side note…on the Kershaw Shuffle 3800 I posted a pic of a couple weeks ago…I used it yesterday to cut some plastic banding strapping material from some pallets that came in from one of our vendors, and completely wrecked the edge…it dulled it to where it would not push cut…or even cut paper at all, and it rolled the edge to one side, effectively forming a slight burr…now I am wondering if for utilitarian cutting like that, if a more toothy, non thinned and highly polished edge is the ticket ? Seems like the highly polished / stropped edges are more suited to slicing. :unsure:
Here is what I have found out? I have been sharpening for some folks that use a knife for work. Contractors and a pizza shop. The fancy high grit finishes slice like crazy and shave arm hair. But my edges that I have done don’t hold well in their work places? When I sharpen to 600 or 800 and strop with the 14/10um balsa they rave about the edge! They cut those plastic bands, cardboard, veggies and say keep it coming. Personally I really like the 800>14/10 balsa the best!
They pick up their knife, shave their arms, smile from ear to ear and then tell me latter how great it cuts! Now ymmv but that is my experience so far? And if anyone wants to chime in and teach a better way? I’m all ears?
Phil, I highly value your opinion on this forum, so I am very curious as to why you don’t use your Balsa strops that much ? For me personally, I prefer those over the leather one by a large margin…just something about the feel of them on the blade for me, the sponginess of the wood, and the less drag with them as opposed to the leather ones ) I feel like, for me anyway, that they are more controllable ? :unsure:[/quote]
I agree also. I like the feel of the balsa better. I wish we all had more time..We need to clone Clay so he can see how the balsa strops effect the edge under the microscope like he did with the leather! :whistle:
My microscope pictures don’t come anywhere near those of Clay. But you can hopefully see that balsa loaded with WE paste is quite effective, pretty similar to leather:
