Protective Boots for new Ball Joint Arms
I had been thinking of a cheap quick and effective means of protecting the ball joints of the new arms from filings etc. The disc over the joints did not seem to offer any real protection.
I came up with the idea of canabalising the fingers off a heavy duty rubber glove.
  • remove the arms from the WE
  • remove the arm from the arm bracket
  • cut the finger off the glove at the base of the finger
  • snip a small hole in the top of the finger and slide it down the arm so that the top of the finger sits above the arm lock nut
  • when in place snip a small hole for the micro adjust threaded end
  • slide the glove over the micro adjust threaded end
  • reassemble the arm
  • repeat for other arm
  • reassemble WE
Tony
Bumping this up.
I was thinking about protection for the upgrade arms joints. I have some rare earth magnets to catch the steel, but unfortunately they don’t get the stone dust.
Anyone using glove fingers or have other ideas?
I used some 2" squares of bubble wrap. It is the right mix of stiffness and flexibility. But not a very permanent solution. (at least bubble wrap is readily available).
Billibong, I have seen your post with the replacement, sealed joints.
I’m using glove fingers. Mine are 14 mil latex, probably overkill but it’s what I had on hand. I didn’t cut the holes in the side of the finger, as TonyJ did, I just left them a bit too long so they bunch up at the bottom of the arm.
this is a great simple idea. So when my wife asks where the thumbs to the dish gloves went…I have an excuse.
Good idea. Simple. Effective .
Think I’ll use it. Seal it with a little rubber cement. Punch a hole for the micro adjust.
It will look better than my plastic wrap and rubber bands :slight_smile:
