I did not know where to put this as it is not a suggestion for a case to be sold by wicked edge, but more of what I found while trying to get a cheap and effective solution for organising and storing my sharpening gear.
First I wanted to get something that would hold my paddles. A visit to the container stor netted me the perfect box to hold 4 sets of paddles. The item is an IRIS in the office business card file. This plastic card case is the EXACT size of 4 pairs of paddles. It is a ridiculously perfect fit with no play but still makes getting the paddles out easy. It measures 4 7/16" x 6 5/16" x 3 1/8" and retails for $5.99 each. Not only is does it have a simple hinged top with clasp, but it is stackable and locks into another unit below it perfectly. The box is also vented on the bottom if you need to store damp waterstones.
Next, I wanted a cheap storage solution for the WE sharpener itself, as well as my storage bins from above. I dont need a $200 Pelican case with custom foam, but need something secure and transportable to move it room to room or take to a friend’s house. Solution? Also at the Container Store… Large SmartStore Tote 50x39x18cm is a perfect solution and only casts $14.99 retail.
It fits the Base across its narrow end like it was made for it. It has two rows of troughs on the outside that are lower that perfectly fit the rubber feet, yet the raised center section supports the base of the stone at the same time. The lid is 1/4" from the top of the vice when the lid is attached and locked into place. This does leave a gap to one side though… which perfectly fits two of the handle boxes from above when turned long end to the base. Again it fits so well it is like it was made to do it. There will be a gap for additional supplies, but I am looking for a box to fit in that gap.
Got even more stones that 8 paddles worth? The paddle boxes from above are stackable and interlock. You can place two of them lengthwise, next to the base, in the large plastic bin and stack them 2 high. This allows for storage of up to 16 paddle sets. But there would be a gap when they are oriented that way… yet again there is an oddly built in solution. When you attach the lid there is an indent for the clasp that holds the lid on. This perfectly takes up the space that would allow the stacked units to slide to the side. The stacked boxes are so close to the lid top (with practically no slack) that the stacked paddle boxes are forced to stay interlocked. You can fit something like a partial roll of paper towels off to that side too to to use that gap.
Now, this is not something that is a padded, locked, or otherwise super robust carry case… but for those looking for a cheap and effective solution for storage of paddles, accessoroes and the WE sharpener that you dont have to worry about coming apart on you as you take it rook to room, it is the best low budget choice. How else can you store your WE and its accessoroes with such a well fitted case for under $28?
If you have any other organisational gear please post it here.
