Need help with technique
Need some help? I can get a really sharp edge but not hair whittling or tree topping? The edge is mirror enough to read back newsprint but…
So here is what I do? Lets say re profile? Start with 100 or 200 diamond and work up a burr using a scrubbing motion. Once I have a good burr I switch to the other side and repeat. Check with loupe. I then remove the burr using single strokes with same grit, just enough to remove burr.
I do this all the way to 800. Then I start single strokes till I have a uniform scratch pattern. Check with loupe and same with 1000.
I then start with my choseras at 1000 and single stroke till I have a uniform scratch pattern. Check with loupe. I then do the same with 2k, 3k, and 5k.
Then I strop with 5um leather and then 3.5 usually 100 strokes. All angles with the diamonds, chosera and strops are verified with a cube. Usually 20 degrees. Did a 15 degree last night? really really sharp but not tree top?
Well what do you guys think? Any tips would really be appreciated!!!
I don’t have much to add. Your process is about like mine.
I raise a burr only at 100. After getting a burr on both sides and I see the “re-profile” is done, I do single alternating strokes each side the entire time from there on.
I have not been able to whittle hair or top it. I think there is some technique to it besides a really sharp knife. Hopefully someone can speak about that.
The difference is most likely to do with pressure and the sheer number of strokes on the leather strops. The compression from the leather can cause the slightest bit of rounding at the edge of the edge, which is the difference between tree topping and not.
You can never be too light on the pressure, and it’s a little tricky sometimes on the WEPS because the paddles being used in a downward fashion means gravity is heavier, or “against” you on the finest grits.
I would increase the number of passes on the 5K (you can’t do too many), getting lighter and lighter as you go, and lower the number of passes on the leather after the 5K to the 3.5 micron only, and only about 10-20 ultra-light passes. This allows the more solid stone to establish the flat bevel, while the soft leather acts more to polish the grooves of the 5K.
I’ve also read in various posts by other people (amongst them Clay) that it can be recommended to back off 1-2 degrees when stropping with leather strops to avoid rounding the edge. (So if you sharpen at 20 degrees, then when switching to stropping with leather, you change the angle to 21 or 22 degrees.)
I support everything suggested. I also alternate every stroke once the bevel is set (in truth it’s just before the bevel apexs but I doubt that really matters)
This is probably right but I’ve given up stropping entirely. I just like the edge I get better whether I finish on the micro ceramics or the 12k super stones. Seems a bit more aggressive. That said, I’ve not tried whittling hair. With my eyes, I can barely even see hair:) But I know how my edges feel in use and I get what I like.
Ken
This is actually backwards… Clay lowers the angle 1 or 2 degrees… so he would drop to 18-19 from a 20 deg. angle.
That being said, while I have tried this, I still get a better edge raising the angle to strop… even though it contradicts the microscope photos Clay has posted… and my own attempts at stropping at a lower angle. (So use what works for you). :slight_smile:
I think pressure is a big culprit (at all levels, but especially the finishing stones and strops), that’s probably what I’d look at first.
All the suggestions so far are good. Ken has a point… you might try testing your edge before you strop, and see what it’s like.
Yes you’re right, I got it backwords in my mind!
The forum posts I was referring to was from this thread:
WE forum thread.
(and actually both lower and higher angles are tested there!!) :stuck_out_tongue:
[quote quote=“johpe” post=9931]Yes you’re right, I got it backwords in my mind!
WE forum thread.
(and actually both lower and higher angles are tested there!!) :P[/quote]
Thanks for posting that, I’d forgotten that I’d asked him to try a 4-5 deg. higher angle. Right now, I’m just doing 1 deg. higher. That’s a good thread to review.
Thank you Everyone! I have learned a lot very quickly! I’m going to go try it out now. I will report back latter this evening.
w[quote quote=“cbwx34” post=9930][quote quote=“johpe” post=9923]I’ve also read in various posts by other people (amongst them Clay) that it can be recommended to back off 1-2 degrees when stropping with leather strops to avoid rounding the edge. (So if you sharpen at 20 degrees, then when switching to stropping with leather, you change the angle to 21 or 22 degrees.)[/quote]
All the suggestions so far are good. Ken has a point… you might try testing your edge before you strop, and see what it’s like.[/quote]
This is great info.
I use each and every suggestion that’s been posted on this thread.
Here is my technique
1.Consistency is key
2.use light even pressure
3.remove burr often (I use a balsa stick which i run along the edge)
4.take your time and pay attention
I managed to use diamond stones 1000 grit, balsa 14&10 paste and leather 5&3.5 paste strops to get a hair whittling edge. I do the same thing as you but I also create a large burr at 1000 grit on both sides, removing burrs with balsa stick and then continue to work both sides at 1000 grit using very, very light pressure. I clean the burr again with the balsa stick gently a couple times. I then switch to my 14&10um balsa strops and after a few strokes I test the edge at several points with a hair, at this point some places are hair whittling. From there I feel the edge by constantly test the edge with a hair and strop with balsa till the entire edge is hair whittling before moving to the leather strops.
I just received micro fine ceramics and nano cloth strops with 1&.25um sprays but have not yet been able to get a hair whittling edge, but I know its because the ceramics are still new and being worked in. It should be possible to get a hair whittling edge on the ceramics in the near future though.
Its a great feeling to get a knife that sharp, have fun dude.
Nick
Well fella’s, I’m having a different problem with checking the hair whittling edge on my knifes. For the past 10 years I have been shaving my head and the wife is getting tired of me sneaking up behind her and snatching a couple of hairs from her head. :woohoo: I’ll have to stop that for a while or my arm will be too sore to sharpen any knives. She said she would cut off a few but lets face it, it’s just not as fun that way. :slight_smile:
Well I tried??? I thought I followed advise to a tee? The blade was sharp, but really no sharper then I have already done? I’m not sure what I’m doing wrong? I used feather light 5k choseras 350 strokes? i’m going to grab anther knife and try again? I’ll report latter.
lol, less painful way, just take the hairs off her hairbrush, I usually brush or comb my hair to acquire a hair, it’s less painful that way
Trying another knife is a good idea, to see what you get.
hair whittling with Wicked EdgeThere’s a few of YT videos showing some technique doing this… . ModifiedZ has one that’s almost an hour that’s pretty detailed, smokeeater908 has a brief one that’s worth watching too. (Both should be near the top of the search).
Nick has a good point in his post… you might try testing your blade as you go.
[quote quote=“nicholas6225” post=9949]
lol, less painful way, just take the hairs off her hairbrush, I usually brush or comb my hair to acquire a hair, it’s less painful that way[/quote]
Brilliant! Solves a big problem for me :slight_smile: I no longer have to prowl the halls at Wicked Edge for volunteers, I’ll just grab my wife’s and daughter’s brushes!
Little tip if you’re having trouble whittling hair. I have found it’s much easier to get a hair to split if you hold the hair by the tip (not the root). Hair is scaley and if you hold it by the tip, you are going against that grain and can get the whittling action started more easily.
If I walked up behind my wife with a knife . . . . . . . she’d turn around and shoot me with her gun !
Oh, you got me wrong. I would never try to cut some of her hair, I just grab a couple and pluck them out. :woohoo:
[quote]There’s a few of YT videos showing some technique doing this… hair whittling with Wicked Edge. ModifiedZ has one that’s almost an hour that’s pretty detailed, smokeeater908 has a brief one that’s worth watching too. (Both should be near the top of the search).
[/quote]
I watched ModifiedZ video and followed it exactly. Took about four hours to do my knife. It came out seriously sharp! But not hair whittling? I was however able to tree top a couple of arm hairs but even that was pretty sad?
I did notice at the end of ModifiedZ video he writes in he could not whittle hair till he used .5 paste.
Are you guys using the paste or am I just missing the boat?
[quote quote=“EamonMcGowan” post=9992][quote]There’s a few of YT videos showing some technique doing this… hair whittling with Wicked Edge. ModifiedZ has one that’s almost an hour that’s pretty detailed, smokeeater908 has a brief one that’s worth watching too. (Both should be near the top of the search).
[/quote]
Are you guys using the paste or am I just missing the boat?[/quote]
I guess I’m into old threads today… :slight_smile:
I found that holding the paddles for a consistent angle was key. Since there’s play between the paddles and the guide rods, you may not be hitting the bevel exactly the same with each pass (I measured a .4 to .5 degree variation). I used ModifiedZ recommendation: grasp the paddles so your index finger rests at the top and pushes toward the clamp, while rotating your wrist slightly to pull the bottom away from the clamp. This way you hit the bevel at the same angle every time. The first time I tried this, I produced a solid hair whittling edge.
-Pie
