Here is a copy of the template I plan on using for each knife.
Huh, it did’t post
KNIFE
Manufacturer:_____________________________ Model:____________________________________
Where bought:____________________________ Date:________ Price:________
Data:
Overall length:_____________________________
Blade length:______________________________
Cutting edge:_____________________________
Blade thickness:___________________________
Blade material:____________________________
Blade hardness:___________________________
Blade style:_______________________________
Blade grind:_______________________________
Blade finish:_______________________________
Edge type:________________________________
Handle length:_____________________________
Handle thickness:__________________________
Handle material:___________________________
Handle color:______________________________
Liner material:_____________________________
Weight:___________________________________
Blade angle:______________________________
Angle:____________________________________
Mark:____________________________________
Depth:____________________________________
Sharpening progression:_______________________________________________________________
_____________________________________________________________________________________
Date Weight Length Height
Before/After Before/After Before/After
KNIFE
Data:
The bottom 2 lines are suppose to be spread out in table format.
There are a couple of excell spreadsheets that work great for this in the downloads section.
http://www.wickededgeusa.com/downloads/
you could edit them to have any of the colums you list. It is important to keep track right away and keep notes. It will save you time..
:whistle:
speaking from experience here. I love the one with the logs. It works great!
Zamfir,
That’s what I did. On my mac an Excel like program is called numbers. That’s what I used.
[quote quote=“SHVentus” post=19784]Zamfir,
That’s what I did. On my mac an Excel like program is called numbers. That’s what I used.[/quote]
Knife DatabaseI hope you’ll post your knives to the ![]()
Hey! I totally forgot to do that!
Thanks for the reminder.
