My first week with the WEPS
The knife was very thin so while it read about zero degrees on the left side, it read about 3 degrees on the right side of the blade. I split this in half to subtract 1.5 degree from the left and add 1.5 to the right making it a true 18 degree bevel. I guess the knife could’ve shifted though I thought it was solid. The bevels turned out even and it was laser sharp at 1k grit.
For the Volli I did the same thing as you suggested and don’t know why I was throwing myself off in my head. I matched the factory angle which was 20 degrees per side for a thin, even bevel. The stones are getting more broken in and it’s reflected in the polish. I also tried stropping at 2 degrees lower for the first time, and it yielded a ridiculously sharp edge. I think this will be my go to technique for stropping from now on. This is all the way to .5 CBN on roo.
My hand positioning with the thumbs in the second indents from the top with my pinkies locked on has become second nature now. As the diamonds break in more I’m getting crazy sharp edges. I like this system so much more than the EP it’s not even funny. Sharpening is enjoyable to me again when before it felt more a chore. I could literally sit and sharpen all day with the WEPS or as long as my back doesn’t stiffen too much ;). It’s true when they say don’t judge the system by your first or even fifth knife, even if you’re already “good” at sharpening via other methods.
nice man! that turned out beautiful!!!
Thanks for the photos. Glad you are getting good results. WhenI first started I was skeptical about the whole diamonds breaking in thing, but it was true and it just got so much better.
Thanks for the kind words :). I’ll be sure to post more pics as I do some more knives to this level of finish.
I just bought my Wicked Edge sharpening system off of E-Bay…it has all the bells and whistles…the first two knives I sharpened were both from Boker and I was truly disappointed with the results…the knives were much sharper before I worked them…now you could run them over your throat and put pressure on them and not even scratch yourself. I have followed all the instructions…and watched all the U-Tube videos of how to use the system…copied the techniques and still no decent results..
I was hoping that someone in the forum could give me some pointers on what the heck I might be doing wrong…I have a Sharpmaker from Spyderco and I can use it for good results..so I have an idea on how to sharpen a knife…so I am puzzled as to what I could be doing that might be wrong on a system that on the surface looks so easy to use…help!
[quote quote=“Rackenhack” post=17959]I just bought my Wicked Edge sharpening system off of E-Bay…it has all the bells and whistles…the first two knives I sharpened were both from Boker and I was truly disappointed with the results…the knives were much sharper before I worked them…now you could run them over your throat and put pressure on them and not even scratch yourself. I have followed all the instructions…and watched all the U-Tube videos of how to use the system…copied the techniques and still no decent results..
I was hoping that someone in the forum could give me some pointers on what the heck I might be doing wrong…I have a Sharpmaker from Spyderco and I can use it for good results..so I have an idea on how to sharpen a knife…so I am puzzled as to what I could be doing that might be wrong on a system that on the surface looks so easy to use…help![/quote]
Rackenhack,
Welcome to the forum. Thanks for jumping on with our questions. I’m sure we can help you get screaming sharp edges in pretty short order. To start, please take a look at this FAQ article: https://www.wickededgeusa.com/categoryblog/118-i-just-got-my-wicked-edge-and-sharpened-my-first-knife-its-not-as-sharp-as-i-thought-it-would-be-whats- It’ll help you identify and eliminate all the common causes of not getting your knives as sharp as you’d like them to be. Please keep telling us of your results as you go.
There are a lot of very knowledgeable, skilled sharpeners on the forum that will be able to help you out.
I had the same thing when I bought it. I didn’t really think it mattered about the stones breaking in, but it does. I also came from the sharpmaker. When I used it, I never raised a burr on it. Once. And I could get some pretty sharp edges on that thing. Then I went to wicked edge and I made it stupid dull. I bought a jewlers loupe and I saw I wasn’t getting to the edge. for me, getting the burr was the first problem I had to figure out. After getting the burr thing down, next was technique. I do one side at a time. I am not ambidextrous at all. What I do is I raise a burr on the right side, then left, then right, then left. That is with one grit. I only do the scrubbing motion, going up and down, with the 50s, 80s, and 100s. After that I only draw the stone upwards. I started with the regular arms. To get the angle right I had to push the top of the stone in, pull the bottom out while using it to take up the play. Recently got the pro pack 2 upgrade kit, and it really is night and day if you want to tweak out. That being said I did get very sharp edges with the original arms, but mirror edges with pp2 arms. But step one is breaking in stones. Hope some of this makes sense. I was super disappointed when I first got it. By a week larer, albeit heavy usage, I couldn’t of been happier. And then I upgraded the arms, got the 50/80 set, 1200/1600 ceramics and now it’s amazing. Let me know if I can help. Hope this helps someone lol.
Well the edges are getting better and better as I’ve settled into a consistent hold on the paddles and the stones get more broken in. Stropping two degrees lower is producing hair whittling edges right on the machine.
My question now is tanto blades. I’ve watched Clay’s video, but have heard of some different approaches on tantoes. I was wondering what some with a lot of tanto experience do? Keep the blade in one spot and work both edges from this position or reclamp for the tip? Easier to turn the machine around and sharpen towards the heel?
[quote quote=“uofaengr” post=18091]Well the edges are getting better and better as I’ve settled into a consistent hold on the paddles and the stones get more broken in. Stropping two degrees lower is producing hair whittling edges right on the machine.
My question now is tanto blades. I’ve watched Clay’s video, but have heard of some different approaches on tantoes. I was wondering what some with a lot of tanto experience do? Keep the blade in one spot and work both edges from this position or reclamp for the tip? Easier to turn the machine around and sharpen towards the heel?[/quote]
I would say that it is easiest however it is most comfortable for you… there are more than one way to sharpen tanto tips… I have sharpened it by leaving it clamped in the vise and not re-positioning, and I have also re-positioned (which you will need to do if you want a precise angle because there is no way to know exactly what the angle at the tip is if you don’t re-position). The biggest thing is to not let your stone roll around your tip and dull it from what it could be (a needle).
When I sharpen customer tantos at shows, I remount the knife to work on the the front of the blade. It takes a little longer to do it this way since you have to start over and work through all the stone changes but if you’re looking for the bevel to be a consistent size throughout then it’s the way to go.
Did this a couple weeks ago but just now getting a chance to post. I did the main edge first and reclamped to get the tip. With the knife being so long I rested it on the base and it held sturdy for the tip. The owner had said he used a buffing wheel on this knife and the transition was noticeably rounded. I think it turned out pretty well compared to how it looked in the beginning.
My question now is do others check their angle between grits on the diamonds? I’ve done that on some knives and have found variance nearly as much as 0.4 degrees or so. Would the SWAT jigs be a quick remedy for this or do you not worry about it? I’m using the old arms by the way and it can get tedious tightening and untightening. I get pretty good polishes but have wondered if the angles not being exact have led to more scratches remaining. It’s difficult to check the angle on the ceramics since obviously there’s no metal to stick to and they tend to want to rock a little bit. On the strops I’ve been lowering the angle 2 degrees on the past several knives I’ve done. All the edges are laser sharp even when not checking the angles. The 1k grit edge on my more and more broken in stones leaves a satisfying, sticky sharp edge that makes you all giddy inside. I’d love to see a video demo of the swat jigs with an angle cube and just how they work in general.
[quote quote=“uofaengr” post=18211]
My question now is do others check their angle between grits on the diamonds? I’ve done that on some knives and have found variance nearly as much as 0.4 degrees or so. Would the SWAT jigs be a quick remedy for this or do you not worry about it? I’m using the old arms by the way and it can get tedious tightening and untightening. I get pretty good polishes but have wondered if the angles not being exact have led to more scratches remaining. It’s difficult to check the angle on the ceramics since obviously there’s no metal to stick to and they tend to want to rock a little bit. On the strops I’ve been lowering the angle 2 degrees on the past several knives I’ve done. All the edges are laser sharp even when not checking the angles. The 1k grit edge on my more and more broken in stones leaves a satisfying, sticky sharp edge that makes you all giddy inside. I’d love to see a video demo of the swat jigs with an angle cube and just how they work in general.[/quote]
Great job man! yeah it definitely turned out well! One thing I like to do when the transition is rounded out on tantos is to take your lower grit stones (or belt sander) and re-shape your tanto tip/transition by grinding perpendicular into the edge. Then you can sharpen for a nice clean tanto transition. Now, on to your questions…
I would say that after you check the variance in your stones one good time, you won’t need to check them every time. My diamonds tend to be very uniform in how they were mounted, but others (like Tom - tcmeyer) have reported that they were mounted very “crookedly” to where one side was higher than the other. But the plates themselves were designed to be consecutively thinner so that it ever so slightly widens your angle with each transition (I am talking a very minuscule amount here). And yes, if you are wanting to adjust the for the width of your stones the SWAT is something you need to use (for speed’s sake)… but I find that I don’t need it because I know how my stones perform (even though I have it).
I will have to see, but maybe I can knock out a video soon of what you are wanting. Oh, and one of the keys that I have found with the scratches is to avoid the 100/200’s if you can… if not then spend a LOT of time with the 400’s to remove those deeper scratches, or they will reveal themselves at higher grits (they are very deep).
[quote quote=“razoredgeknives” post=18212][quote quote=“uofaengr” post=18211]
I will have to see, but maybe I can knock out a video soon of what you are wanting. Oh, and one of the keys that I have found with the scratches is to avoid the 100/200’s if you can… if not then spend a LOT of time with the 400’s to remove those deeper scratches, or they will reveal themselves at higher grits (they are very deep).[/quote]
Thanks for the kind words. I sharpened a Contego tonight and will post pics later, but I again checked the angles between stones and even though you said they’re designed to make a wider angle, I found most every stone change to get more narrow or acute than the previous angle.
I sharpened at 18 dps and I found the variance to be as much as half a degree. Got readings of about 18.5 degrees and got some at 17.6 or so. Sometimes less than 18 on the left hand stone and .3 degrees or so wider than 18 on the right hand stone at the same grit. The ceramics were the biggest variance as they were about 17.5 degrees. I guess my question is why do I only need to check the variance once? If I’m trying to get a consistent 18 dps throughout the diamond stones then I still have to put the cube on to readjust. Sorry if I’m misunderstanding.
I wouldn’t mind seeing a video on the swat jig if you ever get the time, and I’m surprised that there hasn’t been an official video demonstrating this accessory. On the Edge Pro you have the drill stop collar trick that makes changing stones a breeze and something like this would be useful on the WEPS. I’m not sure if the swat jigs will even work with the old Gen 2 arms.
Now for a Contego pic. I tried stropping at one degree lower rather than two this time just to see. This thick blade turned out to be one of my best edges period on this system in terms of polish and sharpness. This thick blade was whittling hair and slicing through phonebook paper with fast swipes like it wasn’t even there.
Hopefully Josh will make the video on the SWAT (VSTA) accessory, but meanwhile you can read about it in detail at a forum post I made about a week ago: http://www.wickededgeusa.com/forum/10-advanced-techniques-and-sharpening-strategies/13050-using-the-variable-thickness-stone-adapters
Josh’s point is that he’s checked his stones and he knows that they don’t need any micro-adjustments.
Also as Josh says, the stones (at least the set I have) typically get progressively thinner as you go up in grits and therefor lean farther from the vertical when placed against the edge. The angle should theoretically get higher with each step. I don’t think it’s normal for you to see such large angular changes, especially a decrease in angle! Maybe there’s something amiss with your stones or your setup. The bad stone which Josh referred to had the diamond plate mounted wrong and it was sitting high on one end. It took me three years to recognize it.
I suggest that you check the thickness (face to face) of each of your stones with a caliper and compare one end to the other. If there’s a difference in thickness, it’ll give you a wrong angle. If the face of the stone isn’t parallel to the rod, it won’t cut with a constant angle. And if there’s a difference in thickness, the rod can’t be parallel to both sides. A difference of only 0.010" in thickness from one end to the other will create a 0.1 degree error.
If your stones are all correct, I think that after you’ve settled in to use the VSTA’s, you’ll find that they are a solution to your problem and take only a few seconds extra with each grit change.
Whenever I make an AngleCube reading that doesn’t seem right, I’ll lift and then replace the AngleCube three or more times, to let the sensor settle in properly. You can’t get valid readings by making small adjustments. Kind of like making a small reticle adjustment on your riflescope. Hmmm… I haven’t tried tapping on the 'Cube with a spent case. :stuck_out_tongue:
[quote quote=“tcmeyer” post=18229]Hopefully Josh will make the video on the SWAT (VSTA) accessory, but meanwhile you can read about it in detail at a forum post I made about a week ago: http://www.wickededgeusa.com/forum/10-advanced-techniques-and-sharpening-strategies/13050-using-the-variable-thickness-stone-adapters
Whenever I make an AngleCube reading that doesn’t seem right, I’ll lift and then replace the AngleCube three or more times, to let the sensor settle in properly. You can’t get valid readings by making small adjustments. Kind of like making a small reticle adjustment on your riflescope. Hmmm… I haven’t tried tapping on the 'Cube with a spent case. :P[/quote]
That’s exactly what I meant, thanks Tom! The point is, that if you know how your stones perform (i.e. angle adjustments needed) then you don’t have to re-evaluate every time, especially with diamond plates (because they don’t dish).
I do the same with my angle cube to ensure I am getting an accurate reading!
So Tom, what would you suggest about fixing your stone’s mounting angle if it is off? It may be helpful for those that need the tips/pointers…
Tom, thanks for the detailed response. I understand what you mean about the Angle Cube. We find ourselves looking for pinpoint accuracy out of a device that I think is only listed of having an accuracy of +/- 0.2 degrees so I basically ignore anything in the hundredths column. I lift the stone at least 3, if not 4 times to get the tenth of the decimal to remain consistent at the least 2 out of 3 attempts.
What I’d like to do is mount a knife in the vise sometime this week, start with the 50 grit stone and set it to an arbitrary angle such as 20 degrees. Then I’m going to record what each angle reads as I move up through the stones. No actual sharpening, just checking the angles on the stones. I’ll post my findings, and see what you guys think. Just by looking at them, the plates on the 800/1000 grit stones look thinner than the rest so what you’re saying makes sense.
I mark my stones on each end. One is 1A/1B and the other is 2A/2B. Each time I sharpen I rotate them end to end and left side to right side to make sure the whole stone is getting used. I picked this tip up off the forum here. I’ll note which stone yielded which reading in my findings. It looks like even if I wanted to use the swat jigs, I’d have to upgrade the arms and sigh, that’s another $200 invested.
On a side note, I have done a few kitchen knives sort of speeding through the grits from 100 to 1000 grit. Not really speeding, but not rechecking the angle if you know what I mean. Anyway, I’ve gotten (especially since the stones have broken in) some really, really sharp edges when I’m done with 1000 grit so I just can’t believe that my angles are getting more acute as I progress like I was stating earlier. I don’t have a microscope or anything, but the edges have that perfectly crisp, sticky feel that is really smooth going through phonebook paper. So who knows…
Before you do what you suggest above I would take a caliper, as Tom suggested, and make sure that your stones are mounted parallel to each other… otherwise your readings with the angle cube will be off.
Also, when it comes to the SWAT Clay has confirmed that they are designed to work with the old arms or the new… so you don’t have to make a $200 investment to do that =)
If you want to check them out I can send you mine to borrow so you can see if you like them or not… just let me know via pm, I won’t miss them too much =)
[quote quote=“uofaengr” post=18228]
I sharpened at 18 dps and I found the variance to be as much as half a degree. Got readings of about 18.5 degrees and got some at 17.6 or so. Sometimes less than 18 on the left hand stone and .3 degrees or so wider than 18 on the right hand stone at the same grit. The ceramics were the biggest variance as they were about 17.5 degrees. I guess my question is why do I only need to check the variance once? If I’m trying to get a consistent 18 dps throughout the diamond stones then I still have to put the cube on to readjust. Sorry if I’m misunderstanding. [/quote]
The problem is that many of us suffer from extreme OCD :lol: . Welcome to the club :wink: .
Normal people sharpen their knives by hand or on a belt grinder (or have it done) without a guided angle device. There even a few degrees of deviation don’t really matter. So the tiny amounts of deviation even the WEPS has in it don’t matter at all in practice.
When I’m out for a hair splitting edge, and use my Chosera’s or Shaptons and watch my edges through a microscope, I try to keep the angle differences withing half a degree. Less is almost impossible, humanly spoken.
And when I sharpen with the stock stones (diamonds and ceramic) I never use the angle cube, but trust solely on the angle bar of the WEPS.
[quote quote=“razoredgeknives” post=18236][quote quote=“uofaengr” post=18235]
[/quote]
If you want to check them out I can send you mine to borrow so you can see if you like them or not… just let me know via pm, I won’t miss them too much =)[/quote]
Thanks for the kind gesture, Josh! But like in Tom’s detailed post showing how the SWATs are used, without the micro adjustment with the old arms, will they be as accurate?
[quote quote=“mark76” post=18238][quote quote=“uofaengr” post=18228]
And when I sharpen with the stock stones (diamonds and ceramic) I never use the angle cube, but trust solely on the angle bar of the WEPS.[/quote]
Yes, I enjoy being OCD about things like this. It’s all about what level of sharpness/perfection can you achieve? I’m not OCD to the point though where I’m using a microscope to really look at the edge. I’m just glad I’ve moved on past the point of super perfect mirror polishes or else I KNOW where all my time and money would be going now. :stuck_out_tongue:
I love this system in that the basic kit is more than enough for the casual user to get screaming edges sharper than they’ll ever really need, but for the true hobbyists and OCD freaks like us out there, we can trick out the system and add on accessories that make “this thing of ours” just that much more enjoyable.
