Ok. So last night I had a nice straight razor to sharpen, made by Theirs Issard. It was actually in decent quality to begin with, here is the progression I went through. I want to also say that I was trying some glass plates on my paddles w/ lapping film and ran into a rather strange phenomenon for which I have no explanation. So here we go… keep in mind I reversed stroke direction so I could ensure where my stones were hitting and to make sure I was reaching all the way to the edge…
this pageThe lapping film I was using was purchased from .
Pre-sharpening to it, it looked pretty good! (compared to some razors I sharpen!)
800 grit Chosera waterstones:
2k Choseras:
5k Choseras:
10k Choseras (note that I increased the bevel angle around 1 dps to make sure I was hitting the very edge as this is the part that actually shaves):
At this point I decided to go to my glass blocks w/ lapping film to see what happened… first up was the 5um film. It looks about right and worked nicely! Notice that it even blended both the bevels into one:
Then I went to 1um lapping film. Keep in mind this is FRESH film, never used before and just put onto the glass. It didn’t get all of the scratches out for how many passes I did (roughly 40 per side):
Ok, so I wanted to do more passes to remove the 5um scratches. I put a little bit of water on the film and wiped it off with a clean paper towel, then put a tad more water on it (to just help a bit w/ lubrication and smoothness of the pass). This may have been caused by switching to edge leading passes, but I think I did edge leading with the 5um film too and didn’t get this. I will have to experiment around w/ this more!! This is what I got :ohmy: :
Wow, what just happened?!?! I have no idea how those big chunks got missing out of the edge but it was crazy, and they were pretty large (you still could not see them w/ the naked eye though I don’t believe). Somehow I am guessing my lapping film got contaminated? So I went back to the 2k and spent about 50 passes per side, note that they are pretty deep and still not removed!
So I used my 2k stone and ground the edge flat (made a couple light passes perpendicular on the edge) and then redid my bevels until they were all cleaned up:
Back to 5k choseras:
Then the 10k Choseras, followed by 1.5um/.5um strops followed by .125CBN spray on Kangaroo leather:
Any ideas?
