Medford tff-1
What angle would I use and placement for a Medford tff-1
Match the current angle that’s on it… if you want a custom angle use an angle cube to determine exactly what angle you are wanting.
How to find the 'sweet spot’If this is your first knife I would wait a bit until you learn “”…
Good advice, you normally can’t go wrong with factory angle for starters. Depends on what you want the knife to do. I have taken some edges to 15 dps and found the steel can’t handle it for my cutting tasks, so resharpened to 17.5 dps and all is good.
If this is your first knife definitely save it for later get cheap knife to practice on.
