Marks from clamp were left on stainless steel Hoffritz slice knife. Clamp did have padding put on but obviously had worn too much-
I am frantically trying to figure out HOW I can REMOVE this.
Thanks to n advance for any recommendation
Hi user6,
Bummer, and are you able to upload a couple of pictures?
Thanks
Hi user6. Thank you for posting about the issue. Can you post some pictures of the blade and marks you’re seeing? Also, which sharpener model are you using?
