Linkage play--your technique for consistency?
One update; I am now cutting a narrow strip off the straw after splitting them so that there is no overlap after they are inserted into the paddles. In two cases it seems that the overlap causes them to be a bit too tight and they drag a bit when used. A drop of oil takes care of it but I’ll most likely redo those two.
I am Curious, is there a specific kind of drinking straw that you have found to work well? Since I read this I have been looking at drinking straws, particularly at different restaurants that provide them. There is a large variation in the ID and wall thickness of the different ones that I have seen. I suppose that I could just start trying them, as it is not that difficult to do. I just thought it would be easier if I could duplicate what you have done and know to work properly.
[quote quote=“PhilipPasteur” post=2203]I am Curious, is there a specific kind of drinking straw that you have found to work well? Since I read this I have been looking at drinking straws, particularly at different restaurants that provide them. There is a large variation in the ID and wall thickness of the different ones that I have seen. I suppose that I could just start trying them, as it is not that difficult to do. I just thought it would be easier if I could duplicate what you have done and know to work properly.
Phil[/quote]
  • 1
the straws I tried were too small on the ID
The first one I tested was from Sonic; but I found the corner store down the street from me had the same one. They are the larger/longer ones for larger drinks About 10 inches long and red.
As I split them lengthwise I am not concerned about the ID and these are larger than the opening for the paddles so they actually “spring open” when inserted into the paddles.
On average the ID of the paddles is 0.270 inches while the swing arms are 0.235 leaving 0.035 "play. The walls of these straws are 0.007 inches thick; so inserting the staw “closes up” the paddles to about 0.255; reducing the “play” by about half. Leaving 0.020 inches free space which seems to work perfect. As stated in my previous post I am now trimming the straws about 1/8 inch so that there is no overlap. On two paddles I believe this is causing a “slight” bind that I can feel but goes away with a drop of oil.
Hope this helps.
I picked up some straws last night and tried the straw bushing idea. The ones that I used were not the same as what you describe. They are about 10 inches long. Long enough that one straw will work for two handles with about half an inch left over. But they are clear or sort of translucent. They will fit over the rods without splitting the straw.I split one side and just slid them into one set of handles. I did not glue them, but they stayed in place while I did about 150 strokes on each side. The staw pieces stayed pu and the play certainly is reduced. I decided to try it like this for awhile. One concern that kept me from gluing the straws in place was that eventually they may well wear out. At which point it would be a PIA to remove them.
Anyway, thanks for the good idea. I ordered some new arms with the modded pivots. Between them (once I get them) and the straws, it will be interesting to see how much more precision I can wring out of the system.
Just a thought, if you are using a wet lube to prevent binding then for those that use the diamonds they might be producing fine dust that could be attracted to the wet lube/grease. I have seen some dry lubes that go on wet and set dry. This resist water and does not attract dust/dirt as much. I think DuPont uses PTFE on theirs. I think some bicycle chain lubes are dry as well.
I tried the straw bushing idea, too. By accident, I discovered something that works very well. I simply cut the length of the straws to fit the entire arms and slid them onto the arms (not into the stones). I didn’t slit the straws and I didn’t use any glue. I got these straws from a Subway Sandwich Shop and fortunately they are the perfect size to fit over the arms. I firmly pushed the end of the straws into the flat pieces of the arms that fit into the black part. The straws stay put very nicely. I just sharpened and polished a knife and the straws never moved from the arms - and I went through a total of 16 sets of stones, choseras, and strops. It may look like the stones might catch on the end of the straws when putting them on the arms but that didn’t happen. The stones all slide onto the arm/straw combo with ease. I’ll report how long the straws last before I have to replace them. Here are some photos. The last two are trying to show how the straws are pushed onto the flat part of the arms.
Note - I used alcohol swabs to wipe down the arms (to remove any oils) before sliding on the straws.
Great concept. I just had one of those “DUH” moments.
Much easier than cutting emough straws for 10 pairs of paddles.
No need to glue anything.. that might be a PIA to remove later if wear becomes an issue…
The straws that I got will not fit the rods without being split…
Off to Subway the next time I can get by there..
Thanks for the concept!!
[quote quote=“wickededge” post=1895][quote quote=“dgriff” post=1894]Thanks, but I’m not complaining about anything, just wondered what others do, and what would you fix? You can’t change the OD of the arm nor the ID of the paddle. I suppose the taper pins could be removed with a drift punch and small diameter non-metallic washers installed to take up the gap between the arm and link. Which end of the pin is the small end? :slight_smile:
Otherwise, no worries.[/quote]
The big end is fluted so it cuts grooves in the aluminum when it’s pushed in. For the mod, I push the pins out, tap one side and replace the pin with a #8-32 button head cap screw and some very little washers. You’re right that there is not much to do about the OD of the arm vs. the ID of the paddle.[/quote]
Hey Clay, is this something I should try doing myself? I don’t have any experience using a tap die. I wasn’t having too much trouble with the slack in the joint because I was doing that same thing and holding the stones in at the bottom…
However, one of my pins just fell out on one arm so I’m going to have to fix it somehow and I will need to have both sides the same. Should I just call in and talk to someone? I think the pin must have been loose from the start because it just slides right out but the one on the other arm is in solid.
[quote quote=“Jet B” post=2236][quote quote=“wickededge” post=1895][quote quote=“dgriff” post=1894]Thanks, but I’m not complaining about anything, just wondered what others do, and what would you fix? You can’t change the OD of the arm nor the ID of the paddle. I suppose the taper pins could be removed with a drift punch and small diameter non-metallic washers installed to take up the gap between the arm and link. Which end of the pin is the small end? :slight_smile:
However, one of my pins just fell out on one arm so I’m going to have to fix it somehow and I will need to have both sides the same. Should I just call in and talk to someone? I think the pin must have been loose from the start because it just slides right out but the one on the other arm is in solid.[/quote]
You can put the pin in most of the way and then put a drop of Loctite in the hole before pushing the pin in the rest of the way. You can also send them in to us and we’ll make the modification for you.
I might just send them in to you guys for the mod. Most of the time, I think I’m dealing with the linkage slack okay but there have been times when I seem to be hitting the edge at a slightly off angle on one side so the mod might help me some. I always thought that my knife wasn’t clamped straight, but it makes more sense that one hand wasn’t holding the stone right while sharpening.
Can I find information on how to send it in on the website here? I’m up in Canada, so it might take a while to get there.
I guess my other option would be to try and find machine screws of the same diameter with washers and a lock nut so I don’t have to tap threads in? That might be a simpler option if I can find the stuff.
I’m guessing it’s just the washers that take out that linkage slop?
[quote quote=“Jet B” post=2249]I guess my other option would be to try and find machine screws of the same diameter with washers and a lock nut so I don’t have to tap threads in? That might be a simpler option if I can find the stuff.
I’m guessing it’s just the washers that take out that linkage slop?[/quote]
Compressing the joint works well at taking out slop, so the nut/screw combo will have a decent effect on its own. It’s even better if you have the washer.
I found the washers on DrillSpot:
DrillSpot
11103084
0.125"ID x 0.25"OD x 0.01"Thick White PTFE Flat Washer, Pack of 50
SKU: 1287009
For my next purchase, I’ll try a little harder to find a brass or other metal washer. The PTFE washers are difficult to work with.
I’m going to go look for some today… I’m hoping a hardware store will have stuff that small. Those are pretty thin washers.
[quote quote=“wickededge” post=2253][quote quote=“Jet B” post=2249]I guess my other option would be to try and find machine screws of the same diameter with washers and a lock nut so I don’t have to tap threads in? That might be a simpler option if I can find the stuff.
DrillSpot
11103084
SKU: 1287009
For my next purchase, I’ll try a little harder to find a brass or other metal washer. The PTFE washers are difficult to work with.[/quote]
No luck finding washers that thin. The smallest brass washers made for machine screws are too thick. Drillspot doesn’t ship to Canada. I might drive into Calgary tomorrow and see what I can find. If I don’t have any luck, I will probably end up sending the arms down to you guys after all.
I think that the subway straw idea is the best yet!!! I’m gonna have to make a special trip there tonight now lol
Go to Subway if you want to do this.
I tried about 5 different convenience stores and three differnt fast food places.
I threw away gallons of softdrinks…
:slight_smile:
I went to subway and could duplicate the results that Holymolar got…
Works like a champ. If they wear out, I know just where to go for replacement parts.
I think that your knife is not clamped in straight. If you have errors due to linkage slack it will not be that consistent as to make one bevel visually different. I have had the same results myself. It has always been with blades that I had to use some cluge to get clamped in firmly. I have tried different materials for doing this, I haven’t found anything yet that avoids the problem. The angle cube is pretty useless for verifying this. If the blade soen’t have enough of a flat for the clamp to grab and center on, there is no reference surface for the cube.
Anyone have suggestions for getting around this??
The only other thing that I can figure that could cause the different bevel size is something that Ken was talking about. If you grind more on one side than the other when you are getting your initial burr you move the edge to one side of the center line of the blade. I have had that happen, but I try to correct it befor proceeding. This has happened to me with blades that I had no question about them being centered in the clamp… After you set the initial bevel, or so it seems to me, and you sharpen with an equal number of strokes and pressure.. it is hard for me to think that you would offset the bevel enough to be visually apparent… especially when being aware and trying to take the slack out of the arms on each stroke.
BTW, at this point there is no good reason for not fixing the joints on your arms. It should help consistency. It will not fix a blade that is not centered in the clamp or overgrinding one side for the initial burr!
[quote quote=“Jet B” post=2248]I… Most of the time, I think I’m dealing with the linkage slack okay but there have been times when I seem to be hitting the edge at a slightly off angle on one side so the mod might help me some. I always thought that my knife wasn’t clamped straight, but it makes more sense that one hand wasn’t holding the stone right while sharpening.
quote]
Couldn’t you just use the knife handle as a flat to measure with the cube?
Just for the record, the left side of the blade always seems to have a slightly lower angle than the right. It’s been that way on every single knife I’ve done, despite me making sure it’s within 1 degree of being centered using an angle cube.
