Klingenmuseum and a 2 meter Swiss army knife
Last week I went to the Deutches Klingenmuseum. That’s German for German Knife Museum. It’s located in Solingen, which happens to be only a two hour drive from where I live. I should have known that before, since it was the first time I ever visited Solingen.
It’s a great museum, with an emphasis on the history of knives. If you want to know what a Celtic knife looks like, or a sword from the middle ages, you should go there.
I made a few pictures of more modern knives.
This is the museum. It is located in an former monastery.
This is a Swiss army knife. Well, it’s probably German, but you get the idea. What you may not see immediately is that is about two meters long: one meter for the handle and one meter for the longest blade. And it’s a working knife!
Another one, slightly smaller.
And you’ve guessed it by now, almost two meters worth of working “pocket” knife.
Thats an awful lot of polishing that has gone into those knives I wonder how heavy they are I guess 4-5 kilos for the big one I bet the blade would cut through quite a few things under its own weight .
the blade in the bottom picture looks 85-90% perfect polishing which is some feat on something that large .
Its like when a hull on a super yacht is faired with epoxy and then faired with sand paper wrapped around1 / 2 metre planks of wood thats an awful lot of work especially on hard steelI imagine these big blades are polished with a similar block technique to avoids hollows from finger tips .
fine tickets there
thanks for the spin
