Here is a new little knife I picked up at Wally World for about $14 or so…has a bottle opener and a flat headed screwdriver tip on the handle end…a little cheapy, but kinda cool and small enough to be useful as an every day utility cutter. I put ( if I’m remembering right ) an 36 degree inclusive edge on it, so 18 per side, starting with the 100 / 200 diamonds up through the super fine ceramics…no stropping on this one.
[quote quote=“JackMontrose” post=13707]Darrell, aprox. how many strokes with the ceramics does it take to get that finish? I see some scratches but, it has a nice reflective edge. B)
Jack[/quote]
Your correct Jack, I cannot ever get rid of all the scratches with my PP2 setup, but I do still get a nice reflective edge though. I don’t really count my strokes as I just go by feel pretty much…but I would guess maybe 20 or 25 per side using the Super Fine and then the Micro Fine ceramics. :unsure:
Thanks Darell, I have the same PP2 but, it’s only a week old so the stones are still pretty agressive. I have been spending a little more time with the 800 - 1000 diamons and the ceramics, but my finish is not as good as yours yet. I haven’t gotten to the strops yet; still getting used to the system (done 12 knives so far). They are extreamly sharp (wich is what I care most about) however, I want to get to the pretty stage soon, just for the fun of it.
[quote quote=“JackMontrose” post=13723]Thanks Darell, I have the same PP2 but, it’s only a week old so the stones are still pretty agressive. I have been spending a little more time with the 800 - 1000 diamons and the ceramics, but my finish is not as good as yours yet. I haven’t gotten to the strops yet; still getting used to the system (done 12 knives so far). They are extreamly sharp (wich is what I care most about) however, I want to get to the pretty stage soon, just for the fun of it.
Jack[/quote]
Jack break that stuff out! :woohoo: Jump in with both feet. You will be amazed at how easy it really is? If you have questions just ask? :unsure: All the old timers on here are just waiting to help out. B)
But most of all have fun! :cheer:
Eamon
I will, maybe tomorrow :unsure: I have been having alot of fun just getting my knives very very sharp. I have been a little intimidated with stropping though. Just don’t want to ruin them first time out, however I think I’m ready to take the plunge. Thanks for the incuragement, I guess its about that time.
Okay if I may? Stropping #101 It was explained to me on this forum to do these things.
(Clays advise) If you are using a 20* angle to sharpen turn it down 2 degrees to 18*. (Curtis says same angle or increase slightly) Start at the heel of your knife and with light to medium pressure, use a edge trailing motion and work up to tip of knife. Repeat say for 20 to 30 alternating strokes?. Clean off blade with a clean cloth and rubbing alcohol. Then repeat this step with the next strop if you want a finer edge?
The real thing here is you really can’t wreck your knife. The worst thing is you might dull it by rolling the edge, but on the WE it is really hard to do! The really great part of the We is you can switch and match? There is no wrong just experiment?
If you do roll your edge? Just go back to the last stone you used and setting to sharpen and clean it up. Your on your way again! Have fun!! :woohoo:
Thanks for the lesson Eamon. My problem is that most of the kitchen knives I’ve been sharpening are at 16 deg. (Shun), I cannot go to 14 deg. without hitting the vise with the strops. I will get out one of my edc’s that I did at 20 deg. and go for it. I’ll let you know how they come out
Sorry my apology I did not mean to come off like a teacher? I guess the 101 would have done that? I am very sorry! Yes you do have a problem with the Shun’s. I am however very interested on how your edc’s goes?
Hope you have a blast! Good luck!
I broke out the strops today :ohmy:
This was a knife I had already sharpened so, I hit it with the 800 and 1,000 diamonds, then ceramics prior to stropping.
I stropped with 5 then 3.5 micron then 1 and .5 micron. The results weren’t spectacular but not bad for the first time;
I did reprofile the first time on the wicked edge (SOG) comes with a strange angle. I set it at 20 deg per side for stones then 18 deg for strops. It is very sharp, I don’t know if it got any sharper by stropping but it shines a lot more. I think I’ll get better with time but, I’m very satisfied for my first attempt. I am really enjoying the wicked edge (makes me smile every time I use it).
Jack[/quote]
yep, know exactly where your coming from Jack…mine is actually not that old yet either, maybe 4 or 5 months now and I have done probably 25 or 30 knives maybe ? One thing I can tell you that is that if you don’t change ( i.e., lower ) your angle before going to the strops, you will round the nice, sharp edge over a tad. I think Clay and others have suggested dropping back 2 degrees ( like from 20 down to 18 ) for stropping, to avoid rounding the edge over as bad ? Also, if you don’t have the Balsa strops yet, I would suggest thinking of getting some…I absolutely LOVE the way they feel over the leather by far ! I also added a set of the Super Fine 1200 / 1600 ceramics which helps polish that edge…at least for me anyways.
As Eamon said, just have fun, that’s what it’s all about. :woohoo:
that edge looks great Jack, nice and even, and looks Wicked sharp ! B)
One thing I do on mine to help polish the edges ( this may be right or wrong ) is when I get to the Super Fine 1200 / 1600 ceramics and the Micro Fine Ceramics, I tend to use a quick up and down scrubbing motion along each side of the blade to help polish it up quickly, before I switch over to the heel to tip alternating strokes per side…hope that helps ? :unsure:
Thanks Darrell, I did drop back from 20 deg. to 18 to strop then went back to 20 deg. and hit it two strokes with the 1000 diamonds. It came out very, very sharp. I have now completed 22 knives and the diamond stones are showing signs of breaking in (better finish). I still use the ceramics but for just getting a sharp edge its almost not necessary. I will take your suggestion and get some balsa strops, I need to order the 50 - 80 diamonds anyway (it just takes to long to re-profile with the 100 diamond stones). Call me crazy but, I’m just having too much fun sharpening knives, the wicked edge is the bomb…
