What is the general rule for hunting knives?
Bevel angle for skinning knife? Hunting knife?
Which is better in the field; a toothy or polished edge?
Thanks for your help.
Marty
Marty
Hey Marty. What are you hunting and what is the steel of the knives in question?
[quote quote=“MartinSinger” post=4369]What is the general rule for hunting knives?
Marty[/quote]
Thanks for responding Clay. The knives belong to my brother-in-law, they are for deer hunting. One is a beautiful, larger knife that is a custom. The skinner is a Schrade Old Timer Sharp Finger flat grind so I don’t know the steel but It profiles pretty easy (maybe not very hard). As a guess I started To profile at 25 degrees and thought I’d try a micro edge at 30 to make the edge last longer in the field .
The reality is that I don’t know what I’m doing.
[quote quote=“wickededge” post=4371]Hey Marty. What are you hunting and what is the steel of the knives in question?
Marty[/quote][/quote]
I think I’d take them both to 20 degrees per side at 3.5um and see how they perform. If the edge isn’t holding up, then you can add a little micro-bevel at 22-23 degrees per side. I’ve done a lot (hundreds) of field dressing and even my AUS-8 knives hold up well in the 20-22 degree range.
[quote quote=“MartinSinger” post=4375]Thanks for responding Clay. The knives belong to my brother-in-law, they are for deer hunting. One is a beautiful, larger knife that is a custom. The skinner is a Schrade Old Timer Sharp Finger flat grind so I don’t know the steel but It profiles pretty easy (maybe not very hard). As a guess I started To profile at 25 degrees and thought I’d try a micro edge at 30 to make the edge last longer in the field .
Marty[/quote][/quote][/quote]
Will do. Thank you.
[quote quote=“wickededge” post=4376]I think I’d take them both to 20 degrees per side at 3.5um and see how they perform. If the edge isn’t holding up, then you can add a little micro-bevel at 22-23 degrees per side. I’ve done a lot (hundreds) of field dressing and even my AUS-8 knives hold up well in the 20-22 degree range.
Marty[/quote][/quote][/quote][/quote]
