I think (Eamon knows this) that there can be many different compounds that are white, or any other color.
I have HF1 and 525 that are both white, way different grit size.
Usually Black is the most coarse, then brown, white, green (often called stainless steel polishing), red, (should be jewelers rouge, but there are many grades of that), blue (general purpose polishing, not much abrasive at all).
Jewelers rouge typically is rated about 5 microns, but has a range of grits depending on the grade that you buy. For what they charge, the HF stuff is probably all over the place.
Don’t buy any of them. Get a quality abrasive with a known concentration and grit range.
Eamon is using his, as am I “white” compound on a belts sander… big difference from precision stropping on the WEPS!!!
[quote quote=“MarcSimon” post=12862]So I’m at Harbor Freight tools and I see all kind of buffing compounds.
I have the WEP Propac 2 what suggestions do you guys have in regards to the compounds I should get that will fill in my stropping?
Also should I get balsa strops or another set of leather.
The compounds they have are Black, White, Red, Blue, Green and Brown.
$5 each ( or $4 with my 20% coupon).
Thank you,
Marc[/quote]
